Vapor/smoke from breather?
I know many of us use valve cover breathers, so I posted up in the FI section.
I've had this breather for probably 5000 miles or so... and now when the car's running I can see faint smoke/vapor coming through it. Do I need to change the filter on this (it looks saturated) or clean it or ???
Thanks in advance for any info...
I'm not sure how often they need to be changed, that's a good question. But I do know it's pretty common for them to smoke like that, mines done it since I put it on.
i thought u need some sort of intake suction to remove the vapor at idle...
i have
so with the ls6 valley cover routed to the ls6 intake with 1 way check valve
valve cover nipple to catch can to induction side of air filter
i have no vapors at idle but
under wot there should be some smoke coming out to relieve the crank pressure
i have
correct, if you have no pcv (or as i insist it should be called NCV cuz its a vacuum) then any pressure will come out of the filter
engines do this on every start up because as the engine cools the hot air inside it has water condense out of it and puddles in places in the block. on start up this water eventually vaporizes and steams out.
still if no pcv you will see some blowby at idle and definitely at wot.
like mecham i draw air through my block and into the intake
i have
i have
clean with gas wait till dry then put back in depending upon ur catch can setup, of its just a fuel filter or a air pump filter u can jsut change it but otherwise lil gas pull the blowby out and u should be good.
