My First Dyno Session...
Old 10-17-2007, 12:09 PM
cool87gn's Avatar
Post My First Dyno Session...
I made 385 rwhp in my 1999 Camaro Z28 with the following mods: Patriot Stage III LS6 style heads, MS4 cam, Precision Race Component Springs (rated to .660 lift), TSP chrome moly pushrods (7.400), Pacesetter LT's, cat-less 3" y-pipe, Mac catback, LS6 intake, ported stock tb, Granatelli 85mm mass air, lid, K&N, ported LS6 oil pump, double roller chain, Vigilante 3200 tc (locked in 3rd gear), Transgo shift kit and tuned by Alvin of PCM for Less in Charlotte, NC. Is this about right for the mods that I have?
Old 10-17-2007, 12:14 PM
The Black Mamba's Avatar
Seems fairly good for an auto IMO.
Old 10-17-2007, 10:56 PM
fuseone's Avatar
i would have thought at least it being in the 400 with those mods
Old 10-17-2007, 11:12 PM
Detoxx03's Avatar
I thought it would have been more. I don't have heads yet and a bigger stall and made 387rwhp on a hot humid day. Solid numbers but I would have though more.
Old 10-17-2007, 11:30 PM
Pharm0r's Avatar
you should be making well into the 400s with those heads and ms4...
Old 10-17-2007, 11:35 PM
g-ryde1's Avatar
i agree with pharmor def should be well into the 400's with that setup
what kind of dyno were you on and what was the weather like?
Old 10-17-2007, 11:44 PM
Pharm0r's Avatar
maybe a mustang dyno? thats all i can really see you making only 385 then again this is all supposing you have a good tune...can you post a dyno sheet?
Old 10-18-2007, 01:05 PM
TXws6's Avatar
yeah it should be well over 400 i would think... I put down 400 without heads....mods in sig
Old 10-18-2007, 01:52 PM
NC98Z's Avatar
Nothing wrong with thoses #s. A4/Vigilante 3200 are notorious for eating up dyno #s. I know look at my Sig. What kinda #s are you putting down at the dragstrip thats the ones that matter. Especially your top end MPH. Then you can use the drag racing calulators like on the www.golenengineservice.com and punch in the dragstrip results and you can calulate all kinda #s.
Old 10-18-2007, 08:24 PM
cool87gn's Avatar
Post Dynojet Dyno...
I was told that I ran out of fuel (it had the stock injectors and fuel pump) when it was on the dyno by the tuner and it was going lean. The temperature was somewhere in the 80's. I have since had the Racetronix fuel pump kit installed with 30 lbs SVO injectors and a TNT nitrous kit. I was pretty disappointed to say the least. What size nitrous shot would you suggest with my fuel system? What are the limits of the LS1? Thank you,
Old 10-18-2007, 09:36 PM
Sunset'01Z's Avatar
ls1's properly tuned are maxing out the stock shortblock at around 500-550rwhp, and if the kit is wet your injectors are fine, dry i'd want some 42's..
you would see probably 20-30rwhp from a 90/90 setup btw, especially since you have some badass heads. the ls6 intake is the weak link in your setup.
if you're still running lean after the fuel pump and injectors, i'd ditch the maf and go S/D tune. i havent heard alot of good things about those granatelli maf's.
Old 10-19-2007, 07:05 AM
cool87gn's Avatar
I forgot one thing, I am ditching that laim *** MAF. I got a 85mm ZO6 MAF new in the box. I heard the Granatelli makes tuning these cars hell.
Old 10-19-2007, 09:05 AM
hndakilr's Avatar
yeah i would estimate 410-440 rwhp with the heads and cam
Old 10-19-2007, 09:29 AM
Sharpe's Avatar
Update this thread, when you go back to the dyno at least with a link to another thread so those of us who would like to know the performance increase will see it.
Thanks.
Old 10-19-2007, 02:50 PM
cool87gn's Avatar
My car is on the same dyno today. Maybe it will work out better this time around.
Old 10-19-2007, 03:01 PM
g-ryde1's Avatar
good stuff bro keep us posted with the numbers man
Old 10-20-2007, 03:59 PM
jed.only's Avatar
well into the 4s i would have thought.
Old 10-20-2007, 05:26 PM
grandsport96's Avatar
spray depends on what enternals you have.. my buddy sprays his 99 ta with a 150 shot all day with the stock enternals but than again he has just headers and intake with the nitrous kit so
Old 10-21-2007, 08:45 PM
slow1999blackz28's Avatar
Pretty sure they're called internals not enternals
Old 10-23-2007, 04:56 PM
chevy11.6's Avatar
you should have low 400 you have alot of mod, the a4 does make a difference
Quick Reply: My First Dyno Session...
