Anyone use one of these?
Old 10-22-2007, 05:27 PM
LS1Tech Sponsor
Superman09's Avatar
Default Anyone use one of these?
http://store.summitracing.com/partde...?part=ATM-5778
Autometers electric wideband.....? Anyone here have one, what are your thoughts on it? Im getting new guages now and figured i need a wideband and ran across this. Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 10-22-2007, 05:49 PM
calongo_SS's Avatar
It looks ok, but you'd have to find out if it has a programmable analog output on the controller for data logging.
Old 10-23-2007, 12:10 AM
2MuchRiceMakesMeSick's Avatar
I bought one thats similar (nexus) and it has +5v out for data logging.
I havent had a chance to try it out yet cause I have been so busy
Old 10-23-2007, 07:02 AM
LS1Tech Sponsor
Superman09's Avatar
hmmm thanks, anyone on here use this one? I'll have to check into it to see if it will data log
__________________
Old 10-23-2007, 08:14 AM
rufretic's Avatar
Hmmm, that's what I need. I can replace my pretty much useless air/fuel one. Now I just need to check if they make it in cobalt to match the rest of mine. If you find out if it data logs, post up.
Old 10-23-2007, 08:26 AM
JMBLOWNWS6's Avatar
Works like a champ! We have it in my buddies C5. Cobalt series
Old 10-23-2007, 08:30 AM
rufretic's Avatar
Nice, thats exactly what I'm looking for. I can't seem to find it in cobalt, do you remember where you got it?
Old 10-23-2007, 08:43 AM
JMBLOWNWS6's Avatar
Yes it does. You can also wire it up and it will alarm in a lean condtion so you get out of it
Old 10-23-2007, 08:44 AM
JMBLOWNWS6's Avatar
I got it thru my supplier (Arrowspeed)
Old 10-23-2007, 10:13 AM
98turbls1's Avatar
Do they have one in the ultralite series??? That's exactly what I need!!!
Old 10-23-2007, 10:41 AM
JMBLOWNWS6's Avatar
http://www.autometer.com/cat_gaugede...id=3604&sid=11
Old 10-23-2007, 11:09 AM
LS1Tech Sponsor
Superman09's Avatar
awesome! Thanks JM, looks like i'll be picking one up in my phantom series!
__________________
Old 10-23-2007, 11:56 AM
JMBLOWNWS6's Avatar
No prbolem guys. I usually handle the wiring duties at the shop so I research this stuff all the time.
JMG
Old 10-23-2007, 01:40 PM
TNTramair's Avatar
is that a feature with the gauge or something you wire up on your own??
how does it work?
Old 10-23-2007, 02:38 PM
JMBLOWNWS6's Avatar
how does it work?
Just have to program the range acceptable and run a micro switch to the TB. Run one side of the micro switch to ground. Then when the circuit closes (Brown wire from the wideband) it will let the wideband know you are at WOT and montior the AFR. If it goes too lean the wideband starts to blink rapidly! Kind of like the way the dynojet widebands work. Only they have a light on the gauge. Hope that hepls.
Old 10-23-2007, 03:22 PM
TNTramair's Avatar
nice. you mentioned something about a "bell"...is that in the gauge or wired in with the Micro switch etc. that your installing. i like the fact of not taking my eyes off the road but being warned of a lean condition with some type of device.
thanx for your input
sorry for the semi-jack.......but maybe this will be usefull information for
other people aswell.
Old 10-23-2007, 03:25 PM
LS1Tech Sponsor
Superman09's Avatar
yep, more info on this wideband the better!
__________________
Old 10-23-2007, 03:28 PM
JMBLOWNWS6's Avatar
No audible alarm Im afarid to open one up to wire in anything like that.
Old 10-24-2007, 07:11 PM
02SSLE's Avatar
I have one in the ultralite series I love it.
Old 10-24-2007, 10:36 PM
Websy21's Avatar
hmmm, never seen this one either looks like a nice unit. I like the series it ahs to match the gauges that most people run. I got the phantom series as well, may have to get this one too. Great info, keep it coming
Quick Reply: Anyone use one of these?
