Best deal on MOSER REAR!!!
Thanks, here are my prices.
https://ls1tech.com/forums/gears-axles/545460-moser-rear-end-prices-exotic-performance-plus.html
You can order them right off of my website.
http://www.exoticperformanceplus.com....html?item=146 12 bolt
http://www.exoticperformanceplus.com....html?item=145 9 inch. Bob
https://ls1tech.com/forums/showthread.php?t=545460
Bought mine elsewhere. I got to pick the componets I wanted in the whole build up. Got a Moser case and 35 spline axles, Strange pro nodular third member with a detroit locker and 4.30 Motive performance gears, set up for a 4 channel with exciter rings installed, drainplug, Shiped to my door within 4 days for $2550. It is going in today. Wish me luck!!!
What are you going to do for a torque arm mount? You will have to get the length of the rear correct, and will probably have to relocate the spring perches and lower control arm mounts, all doable. The torque arm mount is the biggest hurdle. You could do away with the torque arm, and redo the whole rear suspension. Let us know how that works out for you. Bob
I just found a connection for complete 9" with Wildwoods for 1300+ depending on axles and gear choices..... I think I am sold. All new, ready to bolt in. Sure its heavier than a 12, but its going to be bullet proof.
Considering I only make several hundred dollars on a Moser rear-end, I can assure you that you will find this local rod builder to be totally bogus. Bob
