Swap time
Swap time
I have an ABS 3 channel rearend on my 98 z ... I will soon be getting a free low mile ABS 4 channel from my buddy... What needs to be done to make this work????
my 98 Z is a 3 channel, no TCS. The 3 channel rear has one sensor in the housing, right above the carrier's teeth. The 4 channel rear has 2 sensors, one on each axle for the traction control. I don't wanna give you false info (I've never done it, just read about it) but to convert the 4 channel to 3 you have to drill a hole in the housing above the carrier (use your old rearend for reference) and install the sensor. As for the axles I'm not sure if you have to swap those out or not but I think you're ok running the 4 channel axles in it. Do a search there's talk about it every now and then. Oh and I'm also not sure if the 4 channel carrier's have the teeth for the sensor like the 3 channel carriers do. I believe they do but don't rely on my word.
Thanks sounds like work i dont want to do ....
hey man just saw there's a sticky with pictures.
https://ls1tech.com/forums/gears-axles/617761-converting-4-channel-3-w-pics.html
https://ls1tech.com/forums/showthread.php?t=617761
