dumb question
Old 10-25-2007, 04:58 PM
hbgben's Avatar
Default dumb question
what is a ory? Exhaust related
Old 10-25-2007, 05:10 PM
okarcheta's Avatar
It stands for off road y pipe
Old 10-25-2007, 05:11 PM
up2nuthingud's Avatar
most people will tell you to SEARCH, but your pretty new so i wont bust your *****. it stands for Off Road Y-pipe, which means it has no catalytic convertors in it.
Old 10-25-2007, 06:23 PM
hbgben's Avatar
thanks
Old 10-25-2007, 07:32 PM
greysteel_M6's Avatar
I can see you're a newb so I'll expand upon it. The y pipe hooks up the exhuast manifolds to the rear exhaust, when installing headers the y pipe has to be replaced and people tend to go with an off road, without cats because it's considerably cheaper.
Old 10-25-2007, 07:50 PM
hbgben's Avatar
Is there a option if I have to keep the cats?
Old 10-25-2007, 08:08 PM
chrisdacarnut's Avatar
a catted y pipe but they are $$$
Old 10-25-2007, 08:13 PM
schism427's Avatar
is there anything to be had performence from instaling an ory? Or gutted cats for that matter. After going catless should i retune?
Old 10-25-2007, 08:31 PM
Yes you will get improved power the cats are somewhat restrictive, but if you live in a city or state that does smog testing you will get a hefty fine. I love Oklahoma we don't even have vehicle inspections anymore! and after going catless you can get a tuner to delete the rear O2's from the program and then you will have no check engine light. good to go!
Old 10-25-2007, 08:38 PM
gruntwork's Avatar
Get high flow aftermarket cats. Many run them including myself and they don't hurt you as much as people think. I think 5 hp max.
Old 10-25-2007, 10:38 PM
CAMAROZ28SS's Avatar
when i do my headers im taking my cats off
Old 10-26-2007, 12:35 PM
RedRallyeZ's Avatar
you dont gain anything worthwhile for just buying a y pipe without headers. just save up and go all the way with longtubes and either a new ORY setup or duals
to quote JRP from the exhasut sticky:
DO NOT invest in a new y-pipe unless you plan to stick with shorties/stock manifolds, and even at that it's barely worth it since you'll gain practically nothing by a new y on stock manifolds. If you buy a new y for stock manifolds/shorties you'll need to replace the one you just bought if you add lt's or mids in hte future
