what lifters have you guys used with over 16# boost?
7 Second Club
i just ordered a set of heads and am curious as to what you FI guys are doing for a good Hydraulic lifter.... i will probably change to a solid setup next winter (2008) but i dont need that yet.
this winter i will have added-
BS3
AFR -with additional mamo touch up
Kmember and A arms (probably burkhart with motor plates)
new piston- 5cc dish ~ 10.5 CR (rather than my 8:1 -34cc dish)
front strange brakes
if i cant run a 5.9x on my d1sc like Ol' KP i will be pissed...
then i will be forced to spray it .... i will add a double cross bar plate and spray the **** out of it until it burns a few pistons and then back it down a jet size or 2
Thanks,
Tyler
BS3
Thanks,
Tyler
Nope. Search the internal engine section (if the damn search is working) and you can find some good writeups about the caddy lifters from SDPC. I am probably gonna run LS7 lifters next because they are cheaper than the caddys....and it seems to be hit and miss with these damn things.
