Magnacharger dyno results
Old 10-26-2007, 03:39 PM
yotaman96's Avatar
Default Magnacharger dyno results
Finally got the proper pulley on the maggie. I'm now consistently seeing 6-7lbs of boost. I'm still having belt issues. Even shredded one on the dyno. While there, I could see the tensioner not only move up and down, but side to side. One of the tuners actually pointed it out to me after we replaced a belt and said that's the problem. Maybe I just got a bad tensioner?? Anyway, here's the graph. BTW, I think it's time to replace my valve springs. They have a lot of miles on them and I bet the graph would smooth out some with new ones.
Old 10-26-2007, 03:47 PM
John02Hawk's Avatar
Freakin' nice man! Do you have any video clips of your car?
Old 10-26-2007, 03:54 PM
yotaman96's Avatar
I took some video yesterday on the dyno with a regular digital camera. For some reason, it won't play on the computer. I need to find my software for the camera and see if that helps.
Old 10-26-2007, 03:59 PM
HMFDZ28's Avatar
Nice power bro!!!!! You guys have been posting the convincing graphs for me to go Maggie. What are you base mods BTW???
Old 10-26-2007, 04:24 PM
68birdls1's Avatar
Ditto bud
Old 10-26-2007, 08:48 PM
yotaman96's Avatar
Basically just aTR224 cam, TEA stage 1.5 heads, and Yella Terra roller rockers. Bottom end is stock w/122,000 miles.
Old 10-26-2007, 08:57 PM
99mongooSS's Avatar
what did it take to install? Did it fit well undr the dash?
Old 10-26-2007, 09:28 PM
TS6
TS6's Avatar
You have H/C and a blower and made 500 RWHP? Did you ever dyno before the blower? I'm thinking the car probably made over 400 RWHP before the blower.
Old 10-26-2007, 09:42 PM
yotaman96's Avatar
It made 390 before. The maggie isn't about peak hp #'s. It's about making power fast. This car drives like stock w/power on demand.
Old 10-26-2007, 09:53 PM
02SSLE's Avatar
nice numbers
Old 10-26-2007, 10:08 PM
yotaman96's Avatar
It fit after I lowered the k member, cut some of the cowl, and a little under the hood. None of that is noticeable.
Old 10-26-2007, 10:49 PM
Sharpe's Avatar
Wowa!! Holy ****!!! Like, 450 RWT @ like 2500 RPM?!?! With only some mild heads, cam, and a magnacharger?! WOW!!!
Wold lowering your k-member throw the drive alignment or whatever off? How did you lower it?
Old 10-26-2007, 11:17 PM
yotaman96's Avatar
It didn't affect the ride height of the car. Just have to have it alligned afterwards so there's no uneven tire wear.
Old 10-26-2007, 11:28 PM
Sharpe's Avatar
I mean, the angle in which the tranny/drive shaft/rear end connect.
Old 10-27-2007, 12:47 AM
yotaman96's Avatar
The kit contains the spacers and longer bolts needed to lower the k member. It really doesn't change the angle enough to worry about. People put small lifts on trucks all the time without issues. That changes the angle a lot more than this. Even worn out motor mounts can change the angle, but that doesn't have any ill affect on other driveline components.
Old 10-27-2007, 12:55 AM
LivingCanvas's Avatar
Did it increase the front fender gap?
Old 10-27-2007, 01:39 AM
Rickys S/C Z28's Avatar
cool man
Old 10-27-2007, 02:14 AM
HMFDZ28's Avatar
Sweet I have a Vinci XXX (222/228) cam and Crane rockers......this deff seals me lookin into the Dart heads with the charger. Your graph is bassically what my target was....its also good to hear it has the nice driving manners.
Old 10-27-2007, 04:05 AM
yotaman96's Avatar
Not at all.
Old 10-27-2007, 10:06 AM
Ed @ Late Model Speed's Avatar
Awesome numbers Tim! looks like your tuners did a real nice job
On the belt issue, if you need another tensioner, let me know I have one here I can send. Did you get the crank pulley spaced back out properly from the modified lower timing chain gear? If that's still off a little, it could be moving the belt front to back and causing some trouble?
Anyway, congrats on the power, looks good, let me know if you need anything,
Ed
Quick Reply: Magnacharger dyno results
