Yanks October sale still going strong!
Dear Yank. I need some input. I've been running a Fuddle 3k 2.1 str for almost two years and its worked ok. The problem I've been seeing is that on the data logs when I note the launch stall, I've never seen it more than 2600 rpm when I ran 3.23 gears (1.70 60') and now with a 3.89 ratio its around 2400. I expected it a bit lower but"1?#^!!...wait, I think I'm getting frustrated. My complaint with the car has always been low traps also. My last trip down the strip was my best. 12.0@112 - 1.64 60' shifting at 6400 with a 3600 lb car (with driver). 224/230 @ .050 cam. The datta log showed 2300 rpm before the mph started to climb??! I've always launched the car just above idle to get all I can out of the converter. Using the gear and tire calculator vs the rpm I actually go thru the traps at is about 11%. Please keep in mind that the car is still street driven. Planning on adding the juce at some point. Whats wrong and what can you do for me to help me max out my combination. Your input will most likely net you a new customer.
Mec
Mec
I would like to talk to you if you could please call me at 775 826 9955 Or email your phone to dave@converter.cc
I will have answers for you!
Thank you for thinking about YANK
Mec
