anybody use a speed inc. TU0 or TU1 Cam?
looking for a cam for my stock cube LS1 with a CAS twin turbo kit at 10-12 lbs of boost with partriot stage 2 LS6 heads and 9.5:1 compression. looking to make 600HP
would the TU1 cam be good for what im doing? what will it idle like?
also what spring, and lenght of push rods do you use. I am hoping to use my stock length comp cams push rods.
I used the TU1 on my old shop car . 370ci 76mm turbo setup and 10lbs. Made 561/564 with a A/F of 10.9 and timming set at 15 degree's on pump gas. I turned the timming up and leaned it out a little and it picked up alot but never got it back to the dyno before it was traded. It sounded mean at idle, drove well out of boost, and came alive under boost. Its a bad *** cam. Hell the car went 10.7 at 133 in the 1/4 only showing 8lbs on the data log on the FAST XFI.
I have the TU1 in my car right now. I will be doing a sts turbo on it this winter but the car ran good with just the cam only. I havent had a tune yet either. Car idles fine tho. I have beat a couple C6's and some other cars so im pretty excited to see what it will do with the sts kit.
thanks for the info on the TU1 cam guys....I just cant make my mind up if thats the route i want to go or if i should just get the TU0. wish i could hear a TU1 cammed motor idle....anyone got a video or sound clip?
I like to drive this car on the street and like to keep it a sleeper.
Run the TU1 in my car, makes lots of torque.
The TU0 cam was designed by INTMD8 for a small twin/single stock ci, daily driver combination. Stock like idle and low speed driveability, power comes on as big ci N/A would.
I designed the TU1 for my twin turbo 01 SS to have stock driveability but still have power gains over a stock cam.
The TU2 is a great overall cam. Has a mildly noticable idle but still has very nice off idle torque and low speed driveability. We've made 908rwhp with that cam and a 370ci engine with a T76.
I have the TU1 in my car. 383" single turbo ls1 M6 and I like it. It idles nice but still hits. The driveability is good once you dial in the computer. Seems to be working good for me. I'll try and get a video clip of it.
sounds like the TU1 is the cam for me. can you use stock length pushrods with it or will i need to a different length. sucks because i already have comp cams stock length.
a sound clip or video of the TU1 cam would be awesome!!!
