Transmission being ...Stubborn
Old 11-02-2007, 02:34 AM
Wnts2Go10O's Avatar
Default Transmission being ...Stubborn
god damn this things being a pita. clutch is all aligned but the trans doesnt want to seat all the way in.. like its caught up on the second plate (twin disk). any tricks to help?
Old 11-02-2007, 11:54 AM
thesource's Avatar
Its probably hanging up on the pilot bearing . You can use the bolts to suck it in but do so very carefully and by hand not with a power tool . Go back and forth in a star pattern until it pops and pulls up flush then tighten up with an impact .
Old 11-02-2007, 01:07 PM
Wnts2Go10O's Avatar
hhmm, i didnt think it was the pilot bearing. interesting. ill update soon
Old 11-23-2007, 06:09 PM
blackws69's Avatar
did it work? i'm having the same issues with my tranny also. goes through the first plate and stops like hitting a brick wall.
Old 11-23-2007, 09:18 PM
taws6m6's Avatar
i did what the source did. Had the same problem on mine. I just gently pulled it in with the bolts. I knew everything was lined up also, still had the same problem
Old 11-23-2007, 09:50 PM
SilverTxT/A's Avatar
When I did my first clutch swap, I had hung up on my pilot bearing. There is really nothing to hang up on if everything is aligned right except the bearing. I would try to remove and take another stab at it. Pardon the pun!!
Old 11-24-2007, 09:11 PM
blackws69's Avatar
well after two days of fighting with the tranny and a few choice words it slid on. but the last 1/2 inch or so i had to use the bolts to pull it in the rest of the way. on to another piece of the car now.
Old 11-24-2007, 11:50 PM
itspossible01's Avatar
Is this a well known problem?
