moser 12 bolt fluid spray
I don't look under my car every single day but the last time i did look i noticed fluid all over the rear end and back. i have not studied the pattern of fluid spray very close yet but it appears it came out of the vent tube. i recently had the car up to 150mph before i ran out of highway to safely go that fast. i was wondering if this alone would case the problem or do i have something else going on that needs my attention. by the way the car is parked right now. getting the tranny rebuilt and i plan on popping the cover and checking things over a liittle bit. any advise on what to look for? thanks
Venting
Your M/E Bolt-In housing needs to be vented for proper operation. A hole has been provided in the tube and a 1/4" pipe thread air line fitting has been included. After installing the fitting, run a rubber or plastic line from the fitting to a suitable location on the frame. Allow enough line to compensate for suspension travel. MAKE SURE THE END OF THE HOSE IS HIGHER THAN THE VENT HOLE OR YOU WILL LOSE FLUID. Bob
If you have an aftermarket cover (T/A, Mac, etc.) on there and you fill it to the cover's fill hole, you ARE overfilling it!! You should only fill it to the axle's fill hole (this goes for 10 bolts as well).
Really !?!! You've got to be kidding me. Not only is that odd... but that really sucks. What do they expect you to do to fill it ?? On the other hand, what did the instructions say about filling it ?? Thru the vent tube ??
Oh wait... that's how they get people to purchase the useless girdle cover.
The last three or four I did (which was a few years ago) had the fill plug in the stock location. Maybe they stopped that machine process a few years back ??
I'll definately pay close attention to that the next time one comes in the door.
Kleeborp the Moderator™
Nope...not even a boss on mine. I was surprised when I went to look for it and drew a complete blank...
And 5 quarts? Holy geez...I've only got 2 in mine...but then again, I'm not sure what the capacity is since it has no fill plug But from the guys that used to have a fill plug, 2 quarts is the general consensus.
