Rearmount setup new best. 10.139 @132.74
Old 11-03-2007, 02:18 AM
Zombie's Avatar
Default Rearmount setup new best. 10.139 @132.74
Sticky track, left on 9psi. Netted me a 1.48 60' and I still don't have any susp work or skinnies lol. Got some lovely 2.75 gears too. No changes from last time except pulling a little fuel out of it. I'm just getting better at the launch when they have VHT on the track.
60'---- 1.482
330'--- 4.162
1/8---- 6.446
MPH--- 106.60
1000--- 8.444
1/4---- 10.139
MPH--- 132.74
Picked up a smidge of false knock so it killed the MPH and so did the 15-20mph head wind, but it was a very nice pass. I've pretty much sorted out the false knock issue on launch now. Got several clean passes including a few 10.2x ones. Turbo is done, going up 4 psi only netted me 1mph gain. Going to swap to the .96 a/r and see if it improves.
Old 11-03-2007, 02:21 AM
JMBLOWNWS6's Avatar
Congrats 9's soon!
Old 11-03-2007, 02:50 AM
Zombie's Avatar
Originally Posted by JMBLOWNWS6
Congrats 9's soon!
If the head wind would have been a tail wind it could have been tonight. I'll get there eventually. I'm sneaking up on it so I don't scare it away.
Old 11-03-2007, 02:58 AM
JMBLOWNWS6's Avatar
LMAO. It seems like your chasing it forever! Then once you Finally break a 9. You want MORE
Old 11-03-2007, 07:51 AM
smoke20's Avatar
grats on the pass - awesome times -- are you on a trans brake , 2 step???
just wondering i need to get my car to launch in boost trying to figure best way.
Old 11-03-2007, 08:01 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Congratz man... What kind of car is it? Your sig doesn't say.
Old 11-03-2007, 08:13 AM
LS1Tech Sponsor
Superman09's Avatar
Its a red SS Camaro i'm pretty sure...
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 11-03-2007, 08:52 AM
KraZy's Avatar
Nice!
need to get someone to vid those runs for you, the 9 is right around the corner
Old 11-03-2007, 09:59 AM
Dbluegoat's Avatar
very nice
Old 11-03-2007, 10:01 AM
trtturbo's Avatar
Congrats. Jared is going to have you to catch as far as rear mounts go.
Old 11-03-2007, 10:47 AM
kp
kp's Avatar
Congrats, I assume they have the track pretty well prepped for the big street car thing if you are running at Vegas.
Hopefully you will get a couple more chances when the good weather is around.
Old 11-03-2007, 10:50 AM
Photochop's Avatar
That's awesome man! Gives more hope to the good ol' 2.75 gears!!
Have you tuned the car on a dyno ever or just driving around? What converter are you running in it?
Old 11-03-2007, 11:30 AM
Zombie's Avatar
i've tuned on the dyno over a year ago just playing around, made 470 rwhp and went 10.50's @ 130mph. I only use dynos for tuning since they don't give accurate HP readings with a unlocked setup. I do some tweaking on the street and then make adjustments as neccessary at the track. Haven't really had to make any changes for a while though.
Converter is 9.5" vigilante that stalls to 3000 on the trans brake n/a on my setup.
Old 11-03-2007, 01:40 PM
1320's Avatar
unported 317 heads, a stock ls1 intake and zo6 cam, stock crank, and nothing taken out of the car......too.
Ps, I built it.
Old 11-03-2007, 02:41 PM
2002BLKTA's Avatar
You must be keeping your car now?
Old 11-03-2007, 03:11 PM
longrange4u's Avatar
Jermey, THAT IS AWESOME!! CONGRATS!!
Man... that is smoking!! With a 76 too? You have a 9 second run in her yet!!! Again brother congrats! You are posting a good target for me to chase!
Zombie---- TITLE of the FASTEST rear-mount F-bod in the Nation!!!!
Old 11-03-2007, 03:54 PM
cws T/A's Avatar
What tires , hows it cruise on the highway with 2.75's ?
Sounds like the ultimate street car to me , Air conditioning , rear mount turbo , braked 3speed auto , highway friendly gearing , basic engine components using a good gas mileage cam . Congrats .
What compression ratio and psi are you seeing ?
Do you have any pictures of the rear mount , homebuilt or a kit anyone can buy ?
Sorry for all the questions , seems this is a proven setup .
Old 11-03-2007, 04:24 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,100 Likes on 722 Posts
Congrats on the new best!
Old 11-03-2007, 05:00 PM
2001WS6Vert's Avatar
Congrats. I see a lot of guys have problems getting the rear mounts to E.T. well, but you've certainly got it figured out
Old 11-03-2007, 06:38 PM
99Z28LS1's Avatar
congrats on the new times Zombie!
Quick Reply: Rearmount setup new best. 10.139 @132.74
