What gears with Procharger?
Old 11-04-2007, 01:08 AM
my01ws6's Avatar
Default What gears with Procharger?
Trying to figure out whether or not I should swap out my stock 3.42 gears for something bigger like 3.73s, 3.90s, or 4.10s....this is a STREET CAR. The car will also have a procharger pushing around 500whp on no more than drag radials and possibly street tires for awhile.
What do you guys think?
Old 11-04-2007, 07:21 AM
EPP
EPP's Avatar
Do you do a lot of highway driving?
As a rule of thumb six speed cars tend to do very well with 4.10 gears, and automatics do well with 3.73 gears to keep the rpm's in a good range for highway use. The gear change will make a noticeable difference. With your six speed, be prepared to be breaking your 10 bolt rear, as they are quite fragile. Bob
Old 11-04-2007, 10:59 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Don't bother putting a set of gears in your 10 bolt. Just save the money and put it towards a 9" or 12-bolt. You WILL break your 10 bolt with 500rwhp, its only a matter of time. You'll most likely break your driveshaft too... So save the money and when the time comes invest in a solid driveshaft and rear end and a good torque arm. If you can't get a body mount tq arm, at least get a trans cross member with a torque arm mount on it to take the load off the tailshaft of the tranny...
But with all that said, I am running 3.73's in my M6 car...
Old 11-04-2007, 11:58 AM
02SSLE's Avatar
I agree.
Old 11-04-2007, 12:00 PM
Rubberduck's Avatar
I bought a new 9" after reading a lot about other people experience, and went with 4.11 on the m6. Many says it to high for my tt setup, 1 and 2 gear will be useless but 3 and up will be a lot of fun. A 9" with aluminum center is 8lbs lighter then a stock 12bolt buy the 9"
Old 11-04-2007, 12:12 PM
slow95z's Avatar
i busted my 10 bolt first time i ever put slicks on my car and that was just playing around on the back roads around my house... glad i didnt go to the track and do that.
Old 11-08-2007, 08:52 AM
ronin8451's Avatar
I have always been told to stay in the lower 3.xx range with a blower or turbo unless you are only running 1/8th mile tracks. With a forced induction setup you will have plenty of torque for a good 60 foot and won't have to rev the guts out at the top end. My buddy went from 3.73's to 3.23's in his Grand National and still has too much torque off the line and it's just a V6 .
Old 11-08-2007, 04:05 PM
z28misfit's Avatar
3.73 should be probably just about a best of both worlds gear. It shouldn't be too high of a gear or too low of a gear. If you go with a 4.10 there's a slight chance you may need 28" tall tires for the track, but that's not so bad,I guess, I do it.
Old 11-08-2007, 09:18 PM
will82's Avatar
Location: Somewhere Between Mild Insanity and Complete Psychosis
Even with a stalled a4 and street tires, my only regret with this car is the 3.42.
I may switch to 4.10 or 3.90 some day.
3.42 are enough to spin from a stop or slow roll, but that is what drag radials are for. On the highway, I would like a little more SOTP.
Old 11-08-2007, 10:03 PM
Cliff99C5hardtop's Avatar
I have 4.10's and I think that they are too much gear for a FI setup. Before I went FI they were great, I would go through the traps hitting off the rev limiter at 6800 in 4th. If I were to try it now with the blower on the car, I would have to shift to 5th. On the other hand, a friend of mine with about 200 more rwhp has 3.90's on the street and they are fine. My 4.10s on the street can't hook up worth the sh$%......I am going back to 3.42's or 3.73's.
Old 11-09-2007, 05:33 AM
EPP
EPP's Avatar
Turbo cars require a different gear than the centrifical cars, and they cannot be compared. 3.73 gears with an ATI ProCharger is a great compromise. Bob
Old 11-09-2007, 06:33 AM
WAHUSKER's Avatar
I started out with 4.10s when I installed my s/c, and they were too deep. I now run 3.70s and they seem just about right for the track & the street. With a 6 sp, maybe 3.90s would be best?
I had some 2.70s in it for an open road race to drop the sustained rpms down but those were WAY too sluggish for street drivng. Tho I would have liked to take it out on the salt flats with those once (top speed calculator said 260mph )
Old 11-11-2007, 12:14 PM
Moz
Moz's Avatar
I also posted a thread simular to yours.3:73's or 4:10's.I think the majority would vote 3:73's.
Quick Reply: What gears with Procharger?
