MAF Translator ?
MAF Translator ?
I am using AutoTao and MAFT on a 00 Camaro SS...
Is each subsequent MAFT BASE percentage based on the original (nonMAFT) factory settings or the previous average.
In other words do I calculate my next adjustment based on the previous average or the value obtained at MAFT=0?
Same question with the WOT settings.
Thank you,
Scott
Thank you,
Scott
Re: MAF Translator ?
I'm not understanding your question completely, but you adjust your BASE until your LTRIMS are negative. Adjust 5% and if that doesnt fix it, adjust 5 more percent. Continue doing this until your LTRIMS are right where they should be.
