Tubes across valley cover?
Old 11-05-2007, 09:53 AM
Horsepwraddict's Avatar
Default Tubes across valley cover?
Feel sorta stupid asking this, but im wondering what the tubes ontop of the valley cover on my 5.3 are? Their is one coming from each end of both heads and they merge together into one at the front of the motor. My guess is to heat the intake some, egr or some sort of air tube?
Can i plug them? Its a carbed motor and they led to the throttle body, which i obviously dont have anymore. Thanks in advance.
Old 11-05-2007, 10:46 AM
jmm98LS1's Avatar
Those are coolant crossover tubes, best to leave them alone.
Old 11-05-2007, 01:29 PM
...im sensing some sarcasm.. lol....does any coolant actually flow through them or should i block them off.
Old 11-05-2007, 01:39 PM
Ericbigmac83's Avatar
leave them be
and when you take them on and off put the seal on the right way othewise coolant will leak out. and you'll scare the **** out of yourself as you think youre about ready to fire up your new motor but then you see coolant leaking everywhere....
Old 11-05-2007, 01:44 PM
i cant find anything in alldata about the purpose/function of them. Im a little confused, how can i leave it be and coolant not come out of the open end of the line.
Sorry if im just missing something.
Old 11-05-2007, 01:46 PM
there should be a hose from there going into your tb, and from the tb to the radiator. look up throttle body bypass
Old 11-05-2007, 02:14 PM
thats my problem. im using a carb intake. i will look it up thanks
Old 11-05-2007, 02:25 PM
00ssmg's Avatar
Use A Capped Hose And Just Cap It Off That Way You Dont Have To Worry About Any Coolant Issues And Can Just Leave It Alone
Old 11-05-2007, 02:34 PM
thats what i originally wanted to do but lots of the tb bypass threads have said thats a bad idea. Have you done it?
Old 11-05-2007, 02:50 PM
im just going to make a T and run it into the upper radiator hose. Thanks for the help guys.
Old 11-05-2007, 04:57 PM
jmm98LS1's Avatar
From the factory, those coolant tubes run into the throttle body and then to a small fitting on the radiator right by the cap. Since you're going carbed, just run a 1/4" coolant line from the coolant crossover tubes straight to the small fitting on the radiator, effectively bypassing where it used to run through the throttle body. Lots of EFI guys do this as well to keep hot coolant out of the throttle body.
