Best Forced Induction Cam...?
Hi,
my motor is a forged 347 ls6 with PnP 85mm TB, Patriot Stage 2 64cc heads, etc.
And now i'm just trying to pick out a cam.
So far this is the only one that has caught my eye.
http://www.exoticperformanceplus.com....html?item=679
thanks!
thanks!
You can also go with a 224/228 581/581 lift at 115LSA from comp cams that should make a good blower cam. Somtimes I have heard that the bigger blower cam isn't always better, I could be wrong though.
An 02-04 Z06 cam also makes for a pretty good blower cam.
Of coarse there is no real "best" FI cam. It all depends on your driving habits. You could go radical or conservative. I personally am rolling with an LPE GT2-3 cam and am pleased with it. Put down 500rwhp/490rwtq on EPP's dyno with only 6.5psi.
Hi,
thanks!
thanks!
Hi,
thanks!
thanks!
That's a decent choice but an even better one for your application may be the comp off the shelf blower cam I am going with in my new ERIK KOENIG, forged LS6 motor, powered by ECS D1SC blower, which will be running 15 lbs of boost on TEA stage II LS6 64cc heads.
224/230 (XER lobes), 114+2, .581/592
Although often seen in charger applications wide LSA's are not always needed. Get in contact with someone that know what they are doing. For a True custom Grind the entire car's setup comes into play.
