How to splice in aftermarket speakers for backseat and rear hatch
Old 11-08-2007, 04:42 PM
Shackleford's Avatar
Default How to splice in aftermarket speakers for backseat and rear hatch
I haven't even looked at how it might be rigged, but I figured I'd ask first. They're some generic Wal-Mart brand, I believe.
Old 11-08-2007, 06:09 PM
transambandit's Avatar
are you running any amps? are you talking about replacing the stock ones or adding more speakers. Dont get crappy walmart speakers, will be a waste of money, the monsoon speakers are better. Get some decent speakers if your going to put the money into it.
Old 11-08-2007, 07:56 PM
I'm all stock. I paid $30 for 4 speakers.
Old 11-08-2007, 08:01 PM
Well if you look in the sticky in this section there is one that tells which color wires come off the headunit to which speaker, but thats only if you want to run better wires. Otherwise just cut the wires off the old speakers and re-install the new ones.
Old 11-08-2007, 08:21 PM
01ssreda4's Avatar
i wish i woulda known yall liked monsoon speakers so much, mine have been in the front yard collecting rain and dust for the last three months since i pulled them out and threw them on the ground.
Old 11-08-2007, 10:04 PM
Charlie Hustle's Avatar
You can score some cash on ebay for them...that is if they are in good working order
Old 11-08-2007, 10:18 PM
01ssreda4's Avatar
well they were as far as i know when i pulled them out. but as far as ebay goes, im trying to get rid of my monsoon amp and cd player and after 9 days not one single bid. this sucks.
Old 11-09-2007, 07:07 AM
Ungrounded Moderator
WhiteBird00's Avatar
Assuming you have a Monsoon system, don't even bother - take them back to Wal-Mart. If you had the base audio system I still wouldn't install them unless you really don't care about sound quality but at least the installation would be fairly easy. Base audio systems just have four standard speakers (two in doors and two in sail panels) that run off the head unit so you wouldn't be replacing hatch speakers.
Monsoon systems have subs in the sail panels and components in the hatch area (Firebird only - separate woofer and tweeter). The Monsoon amp filters the signal to the subs so you won't get anything but bass regardless of what speakers you install there. Installing cheap (coax?) speakers there will really sound bad.
As for the hatch area, I doubt you got the correct 4" components for that price so what did you buy?
Old 11-09-2007, 08:07 AM
fasttimes1's Avatar
Just spend the extra little money on the right set of door and sail panel speakers.....the best thing I could have done. I almost went your route because Im not huge on bass or big systems, I just like a good, full, clear sound when I listen to my music; I took some advice instead and spent a little money...the sound I got for the money spent is awesome.
Old 11-09-2007, 03:21 PM
Ok, guys, we put the woofers in a little bit ago. They're 300-watt Pyramid Originals. It sounds all right.
What size are the front two speakers? I need to replace the passenger front now.
Old 11-09-2007, 03:48 PM
Monsoon FAQ
Old 11-09-2007, 03:50 PM
Originally Posted by WhiteBird00
6-inch speaker, correct?
Old 11-09-2007, 03:53 PM
Gee, I didn't see 6" speakers mentioned anywhere in the FAQ...
Originally Posted by Monsoon FAQ
Firebird coupes have component 6.5S (6.5" oversize) 2-ohm mids and .75" 4-ohm tweeters mounted separately in the doors, dual voice coil 6.5S (4-ohm + 4-ohm) subs mounted in the sail panels (beside the rear seat), and component 4" 4-ohm mids and .75" 4-ohm tweeters mounted separately in the hatch area.
Old 11-09-2007, 04:00 PM
I saw 6-inch mentioned in the part-numbers. 6.5" Thanks.
