What would YOU like to see in a Vortech big blower setup?
Old 11-13-2007, 11:07 PM
LS1TECH Sponsor
Steve Burger's Avatar
Default What would YOU like to see in a Vortech big blower setup?
Assume ~400 CI
Assume a blower capable of 1K RWHP
Assume good fuel system
Assume drivetrain is up to par
Intercooling is up in the air.
Mounting TBD
Drive system at least 12 rib.
What would you like to see? I would like to hear both street and race opinions.
Old 11-14-2007, 07:17 PM
DeltaT's Avatar
I'd like to see it arrive on my doorstep!
Sounds like fun.
Jim
Old 11-14-2007, 07:30 PM
red beast's Avatar
what head unit??? ysi, x or z trims??? vortech makes nice stuff....
Old 11-14-2007, 08:40 PM
LS1TECH Sponsor
X trim or better. I understand that some new blowers are in the works.
What type of drive system and placement are people looking for?
Old 11-15-2007, 12:08 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I like how PSJ deleted his reply in this thread. LOL
Old 11-15-2007, 12:13 AM
LS1TECH Sponsor
He did not, I deleted the thread and recreated it. Don't know how to fix spelling errors in the title.
Old 11-15-2007, 08:31 AM
7 Second Club
ty_ty13's Avatar
i want to see a A2W IC and atleast 10:1 CR with a solid roller setup squeeling at the pitch of 8000rpms with a g-force or jefco tranny behind it....
that makes my pants a little tight thinking about it ...
Old 11-15-2007, 12:12 PM
2000 Tran Zam's Avatar
I wanna see them make a twin screw setup capable of 1000rwhp
Old 11-15-2007, 01:11 PM
Soul Crusher's Avatar
Twin screw would be neat, but gear drive off the crank (IE no belts) would be even cooler
Old 11-15-2007, 01:21 PM
7 Second Club
ty_ty13's Avatar
gear drive on a big blower would break lots and lots of **** i do believe...
Old 11-15-2007, 01:37 PM
stevieturbo's Avatar
Reliable ones !!!!!!
Id like an XX sized blower, that will fit exactly where my YSi sits. Which already fouls my GTO style PAS pump a little.
Or just to get someone to fit a bigger wheel to my YSi
Old 11-16-2007, 08:05 AM
LS1TECH Sponsor
Twin screw and crank drive are out. Trans will be 3 speed auto unless someone wants to send me something else.
I do like the idea of mounting in the same location as current or even low on the engine. That way belt length can be short.
We should start working on this soon. Mounting location and drive system will be the biggest challenges.
Old 11-19-2007, 02:39 PM
Got Me SOM's Avatar
Assume ~400 CI
Mounting TBD
A YSi should get there otherwise a X trim or Z trim should do it with no problem.
Be curious as to seeing how and where you mount it.
Old 11-19-2007, 03:07 PM
LS1TECH Sponsor
I will be running motor plates. BUT, we want to keep this to something that can be sold as a kit. This gives me a lot of flexibility on location. Also want to it be reverse rotation so we can face the inlet forward. NMCA Xtreme Street allows for this on the LSX platform.
Old 11-19-2007, 03:41 PM
Got Me SOM's Avatar
There was a member on this forum that had the YSi mounted down low on the driver's side, I think he used a cogged belt too. Allowed him to keep all accessories. Looked really trick. It might be tight with the radiator, might have to move that forward. Not sure if it will clear or not. I was gonna do with a ysi with my old car but had to sell her.
Old 11-19-2007, 03:43 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Xtreme Street allows the X-Trim right?
My guess is that you would also need to add a strut brace.
Old 11-19-2007, 03:44 PM
MECHAM's Avatar
when i was supercharged...i had a T Trim mounted where the original Gtrim was. the bracket I had also supported a YSI too
Old 11-19-2007, 04:05 PM
LS1TECH Sponsor
X Trim is allowed. That is where I am guessing we will start. Not sure we will need a strut or if it feasable with a reverse rotation. That all depends on how we end up mounting the head unit.
Radiator is not an issue. Plenty of material to remove from there
Old 11-19-2007, 05:20 PM
Got Me SOM's Avatar
YUP I was gonna get that RMCR kit. just ran out of funds. What would have sucked is the YSi would have been too big to fit under the SS hood so I would have had to get another hood I think. I didn't want to do that so I liked the low location.
Other than the Sunoco hood, I think the SS hood is badazz and really didn't want to change it out.
Old 11-20-2007, 08:06 AM
LS1TECH Sponsor
The head unit will need to fit under my Sunoco hood. We will take that inot account when we select mounting location.
Quick Reply: What would YOU like to see in a Vortech big blower setup?
