New LS1 Owners - Newbie Tech - cutout open or close?
View Full Version : cutout open or close?
myfirstgm
11-21-2007, 02:48 PM
going to the track tonight to see what the car will do with the longtubes and offroad y pipe.car has a borla catback with a cutout.
youngrigo
11-21-2007, 02:49 PM
Open!!!
chavez885
11-21-2007, 02:50 PM
both,do one run with cutout open,one with it closed :D
MJK
11-21-2007, 02:56 PM
If you have the adjustable Borla,isn't it basically a cutout already when using the wide open plate?Or actually no plate?
Maybe there would be a difference between the closed borla and an open cutout?
myfirstgm
11-21-2007, 03:40 PM
i dont think i have the adjustable one
MJK
11-21-2007, 06:05 PM
Aaahhh ok...Good luck at the track man!
95 Z28
11-21-2007, 06:17 PM
Get yourself a baseline run with it closed, and try to duplicate that run with the cutout open and see if you pick up any ET or mph.
NHRAMAN
11-21-2007, 06:19 PM
:D..:devil:
TLUZLS1
11-25-2007, 12:03 AM
What did you end up running? I bet you would have a better 60ft with it closed but a lower trap speed, but in the end I bet having it open would give you better results. I always just run mine open. Just experiment with it.
Reject
11-26-2007, 07:21 PM
probably run the same time if not alitle more slower just more noise with the cutout open
NHRAMAN
11-26-2007, 07:25 PM
SLOWER.......:jest: NOT LIKELY...................:engarde: Probably 3-4 tenths FASTER.
waldershrek
11-26-2007, 07:30 PM
That's what I'd do for my own little bit of knowledge
Cobra2WS6
11-26-2007, 07:33 PM
Maybe 1-2... 3-4 seems a bit excessive
Reject
11-26-2007, 07:35 PM
1-2 seems a bit excessive :jest:
RE AND CHERYL
11-26-2007, 09:39 PM
I'm there, if he got a solid 1/10 I'd be happy.
Re'
ms4z28
11-26-2007, 10:36 PM
forget cut-outs jus get a 3in ORX they flow and u still keep back pressure so u dont lose torque
myfirstgm
11-27-2007, 06:52 PM
haven't ran the car yet,track was closed last week.might go tomorrow i'll let ya'll know the results.before exhaust car did 13.6 @104 spinning the tires in second.hopefully i can learn how to launch the car for better 60ft times.
ms4z28
11-27-2007, 07:02 PM
best u can look at on street tire is a 2.1 60 ft
SmaknaSS
11-27-2007, 07:10 PM
I also say run a few passes with them closed and then a few open to see just how much you gain.
you will be faster with them open. :burn:
myfirstgm
11-27-2007, 07:31 PM
that sounds about right my 13.6 pass was 2.25
conde'strans
11-27-2007, 08:37 PM
I've personally seen a difference with the cutout open at the dyno. Open cutout on 2nd pull gave it 8hp more compared to it closed on 1st pull so it definitely helps.
tx77015ls1
11-27-2007, 09:24 PM
I have stock exhaust and gained 2 MPH in the 1/4 mile with the cut out open.
no change in the time
mchdg86
11-27-2007, 10:48 PM
I gained .1 and a mph and I have true duals. So they must be worth something.
myfirstgm
11-28-2007, 10:56 PM
well ran the car tonight but was only able to do one pass,so i ran the car with the cutout closed and the car ran 13.2 @109 with a 2.2 60ft so I might be a able to do a lilttle better.next time i'll try it open and have my slp lid.
Reject
11-28-2007, 10:58 PM
need to do a back to back run
TLUZLS1
11-30-2007, 03:08 PM
What kind of catback did the car have? I have a hooker catback and an open cutout only gave me 2 more horsepower.
