weird sub problem?
weird sub problem?
Ok with my current set up i am unable to control my sub level through my headunit. i have a alpine cda 9883 head unit with infinity components and a ma audio 1000RMS amp along with two ma audio 12" subs. my friend has a similiar set up just with different amp and subs and she is able to control the bass level of the subs with the subwoofer control on the headunit, except mine does nothing, i thought it was wired in right but i may be wrong. And if i adjust the fade to the front, you can hear the subs quieting down and when the fade is shifted to the rear the speakers fade out and the subs get louder. what is the deal here? simple wiring problem or more?
I agree, certainly plugged in wrong. You didn't take the short cut and run one pair of rear rca cables and spice (y cable) them into both amps?
