I would like pics of madmans lt1 motor plates
I would like pics of madmans lt1 motor plates. I will be putting a new motor in the car in a month or so and would like to see some pics of the motor plates. I think I'm going to order a PA k-member without motor mounts.
Thanks Mike
Thanks Mike
I just picked up a Madman LS1 Plate kit and Mid Plate. The mid Plate comes with the tabs to weld to the frame. I am mounting mine on the sides. When I finish up the 25.5 cage I might add a support to the top of it
The cowl looks much better now, just got painted.
Those were a spare set of heads I had around for mockup, the headers are 1 7/8 Stahl pattern. Had to use the adapters with those heads. My RR AFR's have the holes pre drilled so no need for the adapter.
I don't have my limiters done yet.
