Removed AIR system, what to use to plug the vacuum line?
Old 06-20-2003, 10:38 PM
Mike K.'s Avatar
Default Removed AIR system, what to use to plug the vacuum line?
Hey guys I just removed my AIR system cause it pissed me while I was putting in my new headers, One question though do I need to plug that vacuum line that came out of it, if so what did you guys use a screw or some sort of plastic fitting?
Old 06-21-2003, 04:11 PM
WILWAXU's Avatar
Default Re: Removed AIR system, what to use to plug the vacuum line?
I plugged mine with a screw.. not sure if it makes any difference.
Old 06-21-2003, 05:46 PM
Shorty Director
VINCE's Avatar
I used a screw as well Mike..
Old 06-21-2003, 06:10 PM
Mike K.'s Avatar
Thanks guys, it really does make it easier to work under there.
Old 06-21-2003, 08:24 PM
Cole's Avatar
What vacuum line? When I took my air pump out I left everything attached to it and just unplugged the harness - did I do something wrong?
I didn't unplug any vacuum lines from the engine - when I took the big *** hose out all the way to the pump I then just unplugged the pump and pulled out the whole bracket and everything attached.
Hope I didn't screw something up!
Old 06-21-2003, 08:43 PM
highgmc's Avatar
same here
Old 06-21-2003, 09:29 PM
WILWAXU's Avatar
I believe the part he's talking about is on '00 or '01 and up cars.
Old 06-21-2003, 09:43 PM
Mike K.'s Avatar
yeah on my car there was what I call a vacuum cluster right at the back of the intake manifold close to the drivers side spark pack. There are a couple other lines plugged into it but there was one that hooked into the air system as the big tubes also went to some sort of pipe junction that the vacuum line plugged into.
Old 06-21-2003, 10:37 PM
Cole's Avatar
Whew, thank you WilWaxU and Mike K - had me pulling my hair trying to figure out what I missed!
Old 06-22-2003, 04:38 AM
Restricted User
CAT3's Avatar
I used the bolt from the rear of the Pass. side coil packs, niec place to keep if I ever need the damn thing again. Once you take that puppy off no sense in putting it back on!
Old 06-22-2003, 12:45 PM
Smoke_Ford's Avatar
Yeah, 98 and 99 cars have it different. A lot easier IMO.
Old 06-22-2003, 08:55 PM
gillbot's Avatar
Pluuged mine on one of the coil pack bolts as well.
Old 06-23-2003, 12:36 AM
Mike K.'s Avatar
I will use this one as well if I can find it.
