Need help with 9" Ford... Pics anyone?
Old 11-24-2007, 11:06 PM
Mike96z's Avatar
Default Need help with 9" Ford... Pics anyone?
Alright, bought this 9", ordered a center section, as far as I know, I have to install the center section, the seals, bearings and axles and c clips and bolt it in. I have all the parts needed (I think), I have a general idea how most of it goes intogether. Here are pics of what I have. I think I install the seal into the housing ends, press it in there all the way, then i believe there is a ball bearing that gets pressed into the housing end but not sure exactly where this other bearing goes, looks like just a solid bearing. Also do the bearings get pressed onto the axles? Bearing doesnt go all the way down the axle freely.
Old 11-24-2007, 11:09 PM
Mike96z's Avatar
this is how the bearings should be on the axle i believe
Old 11-24-2007, 11:27 PM
Mike96z's Avatar
should the axles be this close?
the wheel bearing, some kind of solid bearing and the seal
more pics
see how my bearing doesnt go all the way down, does it need to be pressed?
Old 11-25-2007, 03:35 AM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
That housing and axle package is really narrow for a 4th gen.
Old 11-25-2007, 03:57 AM
Revelation Z28's Avatar
+1, that was my first though.
did whoever sold you the kit tell you what exactly it was for?
Old 11-25-2007, 06:09 AM
EPP
EPP's Avatar
Install pic's and info can be found here.
http://www.exoticperformanceplus.com....html?item=145 Bob
Old 11-25-2007, 09:59 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
good eye, Scott. i'm sure that housing has been narrowed. hope this guy's car is mini-tubbed. although Moser's ends are about 2-1/4 inches wide, there should be more space between the spring perches and the end.
Old 11-25-2007, 11:27 AM
Mike96z's Avatar
its 3" shorter on each end, doesnt need to be mini tubbed but needs a deeper dish wheel, thats why I did it to get that offset. i know how the bearings go on now, they need to be pressed on.
Old 11-25-2007, 11:28 AM
Mike96z's Avatar
as far as making sure axles are correct length, are they suppose to be this close when installed?
Old 11-25-2007, 11:14 PM
Mike96z's Avatar
my axles are 27.5"/30.0" and 35 spline.
Old 11-25-2007, 11:15 PM
Mike96z's Avatar
anyone know the standard length on the axles for an fbody 9"?
Old 11-28-2007, 10:15 PM
LS1TECH Sponsor
badpewter-z's Avatar
seals go in axle tubes, put backing plates on axle then bearings pressed on, insatll center section, bolt axles in , done . there are no c-clips in this rear.
al for the length im not sure
Old 11-28-2007, 11:55 PM
sdbrown84's Avatar
Grind that torque arm mount down. Make sure to mock up the arm as I had that trouble already. Get everyhing to fit before you bolt it up.
Old 11-29-2007, 08:35 AM
Mike96z's Avatar
pics of where you had to grind?
