EDUCATE ME!!!!
Old 06-21-2003, 06:42 PM
DEEZ98Z's Avatar
Default EDUCATE ME!!!!
I know nothing about tuning .... and there is alot of it being done to my car since the install. What kind of readings should I be getting?
Any help would be appreciated
Old 06-21-2003, 07:00 PM
Cal
Cal's Avatar
Default Re: EDUCATE ME!!!!
Read this:
http://ls1edit.slowcar.net/files.html
And this:
http://www.blackls1ta.com/LS1-Edit_Tuning.htm
Then:
Drill the TB blade, edit the idle higher, edit the Volumetric Efficiency lower (60-80%,) raise the rev limit to 6700rpm, adjust the LTFT's to -8 @ 18% tps, lean the WOT AFR to 890mv, and kill the COTS. Try the search function for more.
