Wiring 2000 LS1 into 95 Z28
Ok guys any help here is appreciated. I have no idea what to do on wiring this thing up. If anyone has done this on these year models please chime in and let me know where to start Thanks in advance!!
im in the same boat as you, but with a 98 pcm.
I got lots of information from Shoebox's website for lt1's
http://shbox.com
check out http://shbox.com/1/harness_connector_faces.htm
i pretty much used shoebox's diagrams to match up to their corresponding LS1 side connectors schematics.
http://shbox.com
Oh ok I gotcha. So you just got the pinouts for the 2 year models and you are matching them up one by one? Do you know what to do with the starter wire off the ls1 harness? I have no idea where it needs to go on the return side.
some of the ls1 wires that ran to the fender connectors i had to move to the inside connectors. i do not have serial uart wired into the car harness, i just used the "serial data class two" purple wire which is wired into the blue inside connector which goes to the DLC pin 2
allot of wires were omitted, not removed yet, untill i get it running and am sure that i dont need them. I was able to get rid of the c105 fender connector by pinning everything in the larger one.
ill check the power and ignition hot wires that are needed, i had to add a few power and grounds to make my harness work.
on my c100 connector, (big) fender connector i have 4 power wires, 3 of them are only on with ignition, 2 of the 3 being "injector fuse 9" and "injector fuse 10", the third being the pcm ignition feed "Fuse output- ignition 1-type III fuse" (circuit #439)
and the last of the 4 wires being batery positive (hot all the time)
