ls7/ls2 clutch kit question
Old 11-28-2007, 09:34 AM
michaelxx16's Avatar
Default ls7/ls2 clutch kit question
i'm about to buy the ls7/ls2 clutch kit but couldnt find anything about it coming with a throwout bearing, where can i get a throwout bearing for it and whats the price range were looking at? also what kind is it going to be? an ls2 GM t.o. bearing? or...
thanks alot in advance
michael
Old 11-28-2007, 09:59 AM
TARZAN's Avatar
michael
I stand corrected
-Will
Old 11-28-2007, 10:00 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
The kit does not come with a TOB...but they are sold separate if you'd like one. If you buy a new slave cylinder, it comes with a new TOB also (this is the best deal, as the new slave is just a few bucks more than the TOB alone).
This page has everything you need! You'd just go with the standard slave cylinder and LS1 pilot bearing if you want to replace them!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 11-28-2007, 11:35 AM
TY very very much i'm going to be purchasing pretty much everything from you guys i think.. ls7/ls2 kit, slave and master cyc.'s and pilot bearing,,, one question tho, the slave is the 01-02 model right? just making sure before i put in my order
once again tyvvm for the quick response.
michael
Old 11-28-2007, 01:02 PM
Yes, you can no longer even get the early model hydraulics...if you tried to order them, the number would just supersede to the new numbers.
__________________
Old 11-28-2007, 09:30 PM
killer01ws6's Avatar
Hey Matt,
so one would need SDLS7CLUTCH, 12553332, RAM5313, 12570277,15046288, and??
12561465, 12553332?
For a complete rebuild?
if something else is needed or some of the above not, please let me know. Tnks Matt.
Pete
Old 11-30-2007, 08:08 AM
Originally Posted by killer01ws6
Hey Matt,
so one would need SDLS7CLUTCH, 12553332x6, RAM5313, 12570277,15046288, and 12561465x6
Pete
Updated the quantities in your post for those bolts. If you're doing all of that, you might as well throw in a new pilot bearing too! 14061685
__________________
Old 11-30-2007, 10:21 AM
One last question, does the ls7/ls2 clutch kit need to be balanced? or is it prebalanced by you guys?
thanks alot, just ordered everything i needed from you guys cant wait to get it here.
Michael
Old 11-30-2007, 10:25 AM
TheLS1Kid's Avatar
I'm 99% sure it is pre-balanced.
Old 11-30-2007, 10:32 AM
thats good, less runnin around for me. I ordered the pilot bearing, slave which comes w/ the t.o. bearing the ls7/ls2 clutch/flywheel kit and the master cyc.,, is there anything i missed that i'll need for the clutch replacement in my 2000 ws6?
Old 11-30-2007, 10:33 AM
BIG_MIKE2005's Avatar
Just install it exactly like a stock replacement & go. No balancing required or shims. Very straight forward install qith no secrets to make it work. Just bolt it in, bleed it & drive.
Old 11-30-2007, 10:46 AM
will do, ty for all the quick responses, you've been very helpful
michael
Old 11-30-2007, 11:23 AM
TARZAN's Avatar
Copy from install university , for reinstall
"Install new flywheel and torque the 6 bolts progressively to 74 ft-lbs in a criss-cross pattern. Use a flywheel tool (or equivalent to hold the flywheel during torqing. (sorry no picture) Clean the surfaces the clutch will touch on the flywheel and pressure plate with brake cleaner. DO NOT touch these surfaces after cleaning. DO NOT touch the clutch lining! Oil/grease will reduce clutch life and hinder performance of the clutch!
Use a clutch alignment tool to hold the clutch in position and then install the new pressure plate tightening the bolts to 52 ft-lbs in a criss-cross pattern. "
-Will
Old 12-18-2007, 05:10 AM
SYDEWAYZSS's Avatar
so how much better is the ls7 clutch than the ls1 clutch? up to how much hp can it hold?
Old 12-18-2007, 11:25 AM
pro2low's Avatar
i have a ls7 cutch and i liked it before i put a cam in my car. when i got to the track now it slips really bad. you cant ride a ls7 clutch very hard at all or it will glaze. i figured that out the hard way.
Old 12-18-2007, 11:44 AM
Weird, mine hasnt slipped with over a years worth of stop & go daily driving. Hasnt slipped since the H/C install either. It'll rip em lose thru 4th without slippin.
Quick Reply: ls7/ls2 clutch kit question
