Air pump delete Question????
I know there is a write up about it in the stickies, but did not find out about this.
Ok I took all the lines from the air pump stuff finally out from under the hood!!! It has been deleted for awhile but just now got around to making the block off plates. There is a what I think is a vacumm line hooked up to the Solenoid??? that I guess might regulate the air or what not. What did you boy's do with that line? Just leave it hanging or cap it off or what?? I really have no clue what the line is for. Please Help!
Thanks,
Jimmy
Thanks,
Jimmy
Nope, I haven't had the air pump on the car in about a year. I just had the lines running to the manifolds and that crap. I have had it deleted out the computer. Do I need to still pull the fuse?
Jimmy
Jimmy
Ok I got the t-box already out of there. I just undid the line that was on top of it and took it out. The line that is hooked to the top of that is what Im wondering about.
Jimmy
Jimmy
Neither of my SS' have the AIR setup any longer. I'm planning to buy a '99 Z28 in the next week. I want to keep it a little closer to stock but still mod it. I want to eliminate the EGR and AIR to clean it up under the hood. I don't plan on doing any big mods on the car...keepin this one more of a driver. Will I need to get this tuned out?
why leave the pump in but go through all the trouble to pull all the lines and get the codes tuned out? do it right and actually save weight and pull the pump and the whole system. then leaving the fuse in won't matter one bit.
