LQ4 w/ 241's What's my CR?
Im dropping an LQ4 6.0l in my truck and I'm wondering If I put some 241 heads on there with no milling what will my CR be with the stock gaskets or with other aftermarket gaskets?
thanks in advance!
thanks in advance!
It would be around 10:1. I would keep the 317 on there, they flow better then the 241s. Unless you either do not have the 317 heads, or they are the iron (1999-2000) version?
The 243s are the LS6 heads correct?
Also, are you recommending the 317s over the 241s only because flow? do the pro's of the 317s outweigh the pro's of the 241s therefore giving me more power?
thanks
thanks
Well the LQ4 that Im getting is an early 2000 build so it has the iron heads. How much better do the 317 heads flow over the iron ones?
Also, what will happen if I used my heads off of my 4.8? Arent they the exact same as the 5.3s? thanks!
The 317 heads are similar to the 243 (LS6/LS2) heads, but with a larger 72cc chamber. The 4.8L and 5.3L heads are the same. Factory casting of the 4.8L/5.3L do not flow as well as the 243/317 port design. You can find 317s easily to replace the iron heads, and as mentioned just milled them to boost your CR. The 317s are worth it over the stock 4.8L/5.3L and 241 heads.
4.8/5.3 do not flow as well as the 241's let alone the 317's
for what it will cost to buy used 317 and have them rebuilt,
u will be in the $ range for brand new set of ls6/ls2 243 heads
assembled with stock valves and yellow springs, less than 500$
for heads, stock truck intake will bolt right up to 243 heads
add ls6 z06 cam and it should make for a nice pull motor
I know my heads (4.8) dont flow as well as the 241/243/317s, but will the increase in compression benefit more than the flow of the others??
