clutch wont release
clutch wont release
I am having problems with my clutch not releasing. the travel of the pedal, feels like crap, it has 2" of loose travel, and the last half it gains in resistance to the floor where it was starting to get real stiff.
the clutch is a spec stage III+, I used the supplied shim with the kit ( searched and fund some dont use the shim)
i have a mceod bellhousing i figured i would definatly need the shim. Its 1/4" deeper than stock. and a new gm master cylinder
Ive bleed the hell out of this thing but the pedal cant disinguage the clutch.
does anyone know the correct distance between the pressure plate and the T.O. bearing? I think i need more shims, anyone know where i can get some? might have to make one...
Where does the pedal release/engage? Can you shift gears? The fact that pressure build as the pedal is depressed sounds like a hydraulic issue but letsmake sure we are on the same page before assuming. Thanks!
I can get into gear, Even with the 1/4" shim behind it, it still acts the same, pedal feels equal resistance from 3/4 pedal down to the floor, but the bastard still wont disenguage\
i have the spec shim and the 1/4" shim in it right now, it got a little better, but still cant run it.
im assuming the lt1 clutch pedal is identical to the ls1 in the movement correct?
if so i bet that slave is messed up...
ok the lt1 clutch pedal assembly must be different than the ls1, because with the ls1 master cylinder bolted up with the lt1 pedal, there was not the correct ammount of throw that could be achieved before the pedal hit the floorboard.
followed the sticky, did the adjustable master cylinder mod. It works now, it seems i needed a little over 3/8" of extra travel in my pedal to get the clutch to disenguage properly.
To be honest I have never looked at the pedal assemblies on these cars side by side. But, the Master's are different...it is certainly possible that the pedal is too. Let me know what you find. Thanks!
Where can you buy an adjustable Master Cylinder from. I have a 99 Trans AM with a spec 1 clutch and I am having very similar problems. My clutch pedal is letting out at the floor and I am not able to shift into first. I have a new clutch from spec and a F1 Racing Chromoly Flywheel.
Chris did you install the shim behind the slave cylinder? I just want to make sure that you have it in place as this is something that folks have left out during installation and it will cause a low pedal. Let me know. Thanks!
My thoughts...
Rick -
(You may not need all that adjustable MS stuff.)
I replaced everything after putting in a new clutch from a nonsponsored clutch manufactuer based out of South Bend Indiana. (Don't make that mistake!)
The "New, perfect" (according to the maker) clutch that "could not in a million years be part of the problem" was warped - only about 0.015" but enough that it would not disengage. (Arrggghhhh!!!!!)
I've gotten so good at the R&R of my LT1 T56 I can do it in my sleep - did it 6 times in one day!!!
Anyway, take everyhting apart and spin the clutch on the tranny's input shaft - if it is not solid as a rock, NO wavering - then that is your problem.
Good luck!
Good luck!
