ls2 in an f-body?
Old 12-07-2007, 05:07 PM
Soul TKR's Avatar
Default ls2 in an f-body?
if you get an LS2 and put it in an F-body. do you need to get a new wiring harness and/or CPU or anything else like that? what if you went with a shortblock?
just wondering if this is a straight engine swap or will anything need to purchased extra?
also will ls1 headers for an f-body fit on an LS2?
Old 12-07-2007, 05:10 PM
Beast96Z's Avatar
It will all work. You will only need a LS2 conversion kit which you can get from SDPC. It comes with a few harness extensions and misc. covers, sensors, etc...
Old 12-08-2007, 06:47 AM
LS1W66's Avatar
Just make sure you get an LS2 with a 24X reluctor
Old 12-08-2007, 06:54 AM
PREDATOR-Z's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/659189-ls2-conversion-info-inside.html
It is all in there, sticky from Patrick g who gathered various threads into one
Old 12-08-2007, 07:58 AM
Moderator
davered00ss's Avatar
You need to extend the cam position sensor wires the the front of the block and swap 2 wires (dont remember what ones).
Everything else bolts right up.
Old 12-08-2007, 10:40 AM
Beast96Z's Avatar
The extender comes in the LS2 conversion kit... However the 2 wires may still need to be swapped if the vendors haven't fixed the problem yet.
Old 12-09-2007, 05:18 PM
Soul TKR's Avatar
ok thanks for the info guys
Old 12-11-2007, 02:11 PM
DMONEY06's Avatar
can you reuse the same bolt ons for the ls2
