Help!! Broke my Fog Light Switch - Will an Aftermarket Switch Suffice??
Broke the damn switch when I was installing the Raptor Shift Light. Checked around and that damn switch is around 40 bux!! Will and aftermarket switch suffice? If so, which one?
Thanx!
-James
Thanx!
-James
Ungrounded Moderator
It actually has five wires but an ordinary toggle switch will do the job. Two of the wires provide switch illumination when the headlights are on - you don't really need those. The other three wires are the actual switch plus the ON indicator light. You can get a lighted rocker or toggle switch and use all three wires or get an unlighted switch and use only the brown and yellow wires.
