Help!! Broke my Fog Light Switch - Will an Aftermarket Switch Suffice??
Old 12-07-2007, 10:52 PM
02TransAm/Batmobile's Avatar
Default Help!! Broke my Fog Light Switch - Will an Aftermarket Switch Suffice??
Broke the damn switch when I was installing the Raptor Shift Light. Checked around and that damn switch is around 40 bux!! Will and aftermarket switch suffice? If so, which one?
Thanx!
-James
Old 12-09-2007, 10:31 PM
Anyone?
Old 12-09-2007, 11:26 PM
pentavolvo's Avatar
any toggle switch should work.
Old 12-09-2007, 11:43 PM
Yea but the Fog Light switch has about 6 wires connected to it. So I'm not sure if it would work.
Old 12-10-2007, 07:32 AM
Ungrounded Moderator
WhiteBird00's Avatar
It actually has five wires but an ordinary toggle switch will do the job. Two of the wires provide switch illumination when the headlights are on - you don't really need those. The other three wires are the actual switch plus the ON indicator light. You can get a lighted rocker or toggle switch and use all three wires or get an unlighted switch and use only the brown and yellow wires.
Old 12-10-2007, 11:44 PM
Thank you WhiteBird00!!! This is the second time you helped me out in a pickle!!!
Old 12-11-2007, 01:10 AM
tilly's Avatar
Why dont you try to find one in a junkyard. I think a toggle switch in its place would look a little tacky.
Old 12-11-2007, 05:21 AM
02Z28LS1's Avatar
don't put in a regular toggle switch, just find a used one at a junkyard
