need a scr check (seems high)
Old 12-09-2007, 11:04 AM
quick346's Avatar
Default need a scr check (seems high)
I just ran it through a dcr calculater and it is saying 11.80 static
stock ls1 lower .040 cometics and 59cc afr's
if someone could verify if that is right would be a help
thanks,
mike
Old 12-09-2007, 11:12 AM
turbogarrett's Avatar
Yep I came up with 11.84.
Old 12-09-2007, 11:24 AM
TheLS1Kid's Avatar
11.84 is wrong according to this calculator.
I got 11.4:1.
http://www.c5frc.com/calculators/Com...Calculator.htm
Old 12-09-2007, 12:33 PM
Here's the one I used
http://www.smokemup.com/auto_math/dy...sion_ratio.php
Looks like the deck height is different between the 2 calculators?
Old 12-09-2007, 12:49 PM
quick346's Avatar
I got 11.4:1.
I tried that one .if you put the deck ht at .0001 it is 11.7 so the .008 must not be a +.006 because the scr go's up when you put it at .0001 ok whent back in and put the gasket at .034 to make up for the +.006 deck ht and it gave me 11.8
thanks for the help guys
mike
Old 12-09-2007, 12:55 PM
quick346's Avatar
Default dcr calc
ok this is what i am useing but changing the bore to a ls1
http://www.alantripp.com/VE%20calcul...okup%20LS2.xls
came up with 11.79 scr and a 8.69 dcr with the 115 238/242 .605/.610 original spec hpe s cam
