How many sensors are on clutch, brake, assembly? PICS INSIDE
Old 12-10-2007, 07:48 PM
94TA25ann's Avatar
Default How many sensors are on clutch, brake, assembly? PICS INSIDE
I am getting ready to swap in a T56 into my Firehawk.
How many sensors are on the assembly? I think I might be missing one, but I can't really find any pictures that give me a clear view.
If I am missing one, can they be bought from the dealership? Part number?
Thanks.
Old 12-10-2007, 10:09 PM
94TA25ann's Avatar
I think I am missing the switch that sits above the clutch pedal, which is used to let cruise control know when the pedal is pressed down...??
Old 12-11-2007, 09:50 AM
jmm98LS1's Avatar
Yep, looks like you're missing the white switch above the clutch pedal.
Old 12-11-2007, 12:45 PM
94TA25ann's Avatar
What harness is the switch above the brake pedal missing? There are 4 prongs inside of it?
Old 12-11-2007, 01:49 PM
2002_Z28_Six_Speed's Avatar
I think for a M6 the cruise control switches are the same on the gas pedal and clutch pedal. They are small white two pin switches.
The the M5 I think it is a 4 pin switch. Clutch anticipate.
I might be wrong, though.
Old 12-11-2007, 07:46 PM
94TA25ann's Avatar
Does anyone have the part numbers for these switches?
Old 12-12-2007, 04:13 PM
if no one helps ill look up later but busy right now
suprised to see no one answered
Old 12-12-2007, 05:43 PM
chuckyt1's Avatar
Shoot me a note if you can't find one. I think I've got one in a drawer somewhere...
Old 12-12-2007, 08:14 PM
Well this is what the 4 pin one looks like. I think it is only for V6 though.
I know for either car it will have a 2 pin clutch switch over the brake so if someone can just confirm what switch is over the clutch you will be AOK.
IF you need the 4 pin switch it would look like this:
https://ls1tech.com/forums/attachmen...1&d=1197512069
10293267
0150A
MEXICO
I think this is this edited picture you found is how the M6 should be. Hopefully, someone will confirm this. I never had CC in my car. It was already removed when I bought it.
Attached Thumbnails How many sensors are on clutch, brake, assembly? PICS INSIDE-camaroclutchswitch-001.jpg   How many sensors are on clutch, brake, assembly? PICS INSIDE-pedals.jpg
Old 12-13-2007, 12:09 AM
94TA25ann's Avatar
10293267
0150A
MEXICO
I am confused about the switches. I wish someone had a picture of their assembly so i could compare. Is the switch that is above the brake now correct? What all does it go to? There is a slot for a 4 prong connector and a slot for a 2 prong connector, which I am missing the connector for the 4 prong.
Does anyone have pics??
EDIT***I just found this picture on ebay. Looks like I am missing 2 switches.
http://www.auctiva.com/hostedimages/...ats=0&format=0
Old 12-13-2007, 12:30 AM
Look up at my last post. I 2X'ed what you want.
You need those switches and you need the pigtails to wire them in. Then do your wiring.
Old 12-13-2007, 09:12 AM
94TA25ann's Avatar
10293267
0150A
MEXICO
Thanks for the help! I am going to go down to the dealership and see if they can order me those two sensors and pigtails that I need. I will keep you updated.
Old 12-13-2007, 12:06 PM
94TA25ann's Avatar
I found another picture of what I think you are referring to. This must be M6 pedal assembly rather than an M5 assembly.
Does this look correct to you?
This link above seems slow, use this one if it doesn't open.
http://cgi.ebay.com/ebaymotors/98-02...ayphotohosting
Old 12-13-2007, 12:17 PM
That looks like it! It has the correct cruise control switches on there.
That guy wants a pretty penny for his stuff. Doesn't he?
Old 12-13-2007, 09:37 PM
94TA25ann's Avatar
I am going to go down to the dealership in the morning and order those switches for the assembly. I will post the part numbers on this thread when I get home for future reference.
Then it will be time to swap in the T56!
Quick Reply: How many sensors are on clutch, brake, assembly? PICS INSIDE
