worth it to swap in stock 03 zo6 cam?
Old 12-11-2007, 12:35 AM
PhantomR/T's Avatar
Default worth it to swap in stock 03 zo6 cam?
if the cam would be less than $50 from a friend?
Otherwise stock car with a non lockup convertor
Old 12-11-2007, 06:52 AM
COD02SS's Avatar
It's not a bad cam just really small. You'll end up wanting more.
Old 12-11-2007, 12:11 PM
BAD2000TA's Avatar
You'll need springs, too. But, $50 bucks for a cam isn't bad. What's bad is doing all the work to put in a cam that you're going to be disappointed with quickly. Better cams out there that will still give stock idle (if that's what you'r looking for). Try to used parts section for cams for sale. A nice 224 cam would be better.
Old 12-11-2007, 01:29 PM
BurtReynolds's Avatar
I think it is a good cam.You will need ls6 valvesprings $50-$60, 7.400 Pushrods $80-$100. I would do a ls2 oil pump and maybe a pulley if you were going to put in the cam. It is a top end cam and you will not feel the power till 4000-6500 rpm. The good thing is you will not need to change springs every 30k-40k.Ive seen dyno sheets on A4 cars getting 20-26 horspower but not alot of torque. Ther was a guy i knew that had boltons, 3500 stall, 3.73 and tires and went 12.0-12.2 in the 1/4 with 112 et.
Old 12-11-2007, 03:49 PM
_JB_'s Avatar
As much time as it's going to take do swap a cam you might as well get a better one.
Old 12-11-2007, 04:11 PM
HandsomeBWouderful's Avatar
Yep. It's a cam that should have come stock, but not worth it unless you have access to free parts. A stealth, Old-Man, or CheatR cam would be better choices if you want to retain a stock-ish idle.
Old 12-11-2007, 04:12 PM
87gnx's Avatar
With that price, it would be a perfect "sleeper" cam. Not a bad deal i.m.h.o..
Old 12-11-2007, 11:33 PM
SSkillz's Avatar
Its not worth it save your time
Old 12-11-2007, 11:35 PM
KillerZO6's Avatar
your better off just geting a good size cam unless u going to turbo it
Old 12-11-2007, 11:38 PM
oneBADDz's Avatar
For the money and lack on need for tuning? I'd say yes it's worth it on two conditions
1) you can do all the work yourself and don't have to pay somebody
2) you don't mind doing the work for not much gain
Old 12-11-2007, 11:50 PM
The Postman's Avatar
im throwing one in mine, its a great cam for a daily driver, doesn't beat the hell outta the valvetrain
Old 12-12-2007, 01:30 PM
98Z28MASS's Avatar
If you want to run it on the stock tune, then yes it would be worth it. You probably wont get more than 15 rwhp out of it (depending on your current mods), but you will be able to run it on the stock tune without much of a problem. If your going to have the car tune then get a different cam as the gains you will see from the ls6 cam will be pretty mild.
Old 12-13-2007, 02:18 PM
PhantomR/T's Avatar
I'm tuned now, but getting a new one wouldnt be an issue... I want the car to idle as stockish as possible. Doesnt need to sound stock (i'd actually prefer a tiny bit of lope), but I dont want it to be like the one in my truck at idle. Hmm.... decisions decisions
cam in my truck, for reference:
Old 12-13-2007, 02:24 PM
02silvaZ's Avatar
i'd do it if i had a good set of heads to do at same time, and a LS6 int mani or better, a good reliable cam none the less
Old 12-13-2007, 04:18 PM
formula87's Avatar
I agree, save your money
Old 12-14-2007, 02:10 PM
98Z28MASS's Avatar
Well if you can get another tune go with a slightly bigger cam like the CheatR or a 224/224 sized cam as you will still have excellent streetability/driveability yet you will make over 360 rwhp and have some nice lope to it.
