Sub and Amp hook up and Monsoon system...
Old 12-12-2007, 12:13 AM
Restricted User
Zero4488's Avatar
Default Sub and Amp hook up and Monsoon system...
I wanna hook up my sub and amp to the factory Monsoon system....Has anyone done it? How would I run the lines to the amp to get the signal....lemme know...I have a CDT sub and a 1000w Kenwood amp...lemme know....
Old 12-12-2007, 02:54 AM
DUhulk78's Avatar
You have to get a line-level adapter. You can get themfor just a few bucks from almost stereo or electronics shop. It will convert the speaker-level output of the head unit to the pre-amp (line-level) input needed by most amps (you can also buy some amps with speaker-level inputs). They aren't too hard to hook up, and i know plenty of people have done it.
Old 12-12-2007, 05:55 AM
bryan04h's Avatar
^^ agreed, i did that before i upgraded everything, i had a powered sub when i had my car in england and i used a l/l adapter and it worked fine for me
Old 12-12-2007, 10:28 AM
Restricted User
Zero4488's Avatar
does anyone know which wires off the headunit I would need to run the line level off of??? and what does that basically convert it to RCA??
Old 12-12-2007, 02:04 PM
Restricted User
Zero4488's Avatar
bump...anyone???
Old 12-12-2007, 03:32 PM
KEE AUDIO's Avatar
Yes a line level converter is also known as a high to low level converter which transfers speaker level signal to a low level signal which is what your RCA would be on the back of an aftermarket HU with the main difference being output voltage.
You can hook this to any speaker level output on the back of the HU. Personally I would run it off the rear left and right outputs on the back of the stock HU.
Old 12-12-2007, 06:07 PM
DUhulk78's Avatar
Ya, just the speaker wires.
Old 12-12-2007, 10:56 PM
Restricted User
Zero4488's Avatar
alright...can I just tap into the rear speakers and use the converter???
Old 12-13-2007, 06:55 AM
Ungrounded Moderator
WhiteBird00's Avatar
LS1Tech 20 Year Member
No, that's an amplified and filtered signal. You want to connect before the Monsoon amp - either at the head unit or on the input side of the amp itself.
Old 12-13-2007, 07:00 AM
No Juice's Avatar
What if the amp has speaker level inputs? Where would you connect then?
Old 12-13-2007, 07:11 AM
If your amp has speaker-level inputs then you can patch into the speaker wires on the input side of the Monsoon amp without using a line output converter.
Old 12-13-2007, 07:18 AM
No Juice's Avatar
So you tap into the same wires if you're using a converter or an amp with speaker level inputs?
Old 12-13-2007, 07:22 AM
Yes. The LOC takes speaker-level input and converts it to low-level for use on amps that don't have speaker-level inputs. Amps that have speaker-level inputs don't require this conversion so they just connect directly to the speaker signal wires.
Old 12-13-2007, 11:25 AM
Restricted User
Zero4488's Avatar
wow...this is getting complicated...lol...which wire on the head unit is it?
Old 12-13-2007, 12:18 PM
The wire colors and pin positions for both the head unit and the amp are listed in the Monsoon FAQ sticky.
Old 12-13-2007, 03:18 PM
Restricted User
Zero4488's Avatar
Thanks alot....but where do I get a line level adaptor and how much are they?
Old 12-13-2007, 03:21 PM
You can get one from any car stereo shop, one of the big box electronics stores (Best Buy, Circuit City), or even Wal*Mart. They should be around $15 or less.
Old 12-13-2007, 04:16 PM
Rai
Rai's Avatar
couldnt he just tap into the hatch speaker its self
split the wires going to the left(or right) speaker in the hatch ... and split them so they go to the line level filter and the regular speaker
right?
that way you arnt messing around with the stock deck and cutting up its wires
its easyier to do
and you have to use alot less rca cable
Old 12-13-2007, 04:20 PM
Yes, except that you're getting amplified, filtered signal at the speaker from the Monsoon amp. Considering that the amp is under the right hatch trim panel, it's just as convenient to get signal from the input side of the amp rather than the output side at the hatch speaker. Without the added amplification you'll get a cleaner signal to convert.
Old 12-13-2007, 05:19 PM
Restricted User
Zero4488's Avatar
So I can take the right and left channel from the input right before the factory Monsoon Amp....
Quick Reply: Sub and Amp hook up and Monsoon system...
