third gen swap
Old 12-14-2007, 10:07 PM
slolt1's Avatar
Default third gen swap
i am doing the swap and trying to fiqure out where to put the ecm any help will be great
Old 12-15-2007, 12:43 PM
Spike-Z's Avatar
In the engine compartment if youre using a stock harness, or under the dash if you use an aftermarket supplier. You could always extend the wires of the stock harness to put it where you want. I placed mine under the dash, @ the OEM location.
Old 12-16-2007, 10:39 AM
a10beav's Avatar
I did the same.
Old 12-16-2007, 10:49 AM
DiabloFormula's Avatar
Here's what I did.
Old 12-16-2007, 11:06 AM
grifter757's Avatar
Mine is the stock location to.
Old 12-17-2007, 10:25 AM
slolt1's Avatar
are you able to put it in the stock location runing the air box
Old 12-17-2007, 03:12 PM
a10beav's Avatar
You mean the heater core? Yea, it'll fit. It's a tighter fit than the stock ECM but it works. You'll just need to create a bracket to hold it in place.
Old 12-17-2007, 09:04 PM
ghettocruiser's Avatar
I put mine in the stock location. NO extension of the PCM wires was needed... Only a handful of the wires for the three "C" connectors needed tobe lengthened a bit, but only because I wanted those connectors to sit on the wheel well just like on the 4th gens. I could have gotten away without extending them.
J.
Quick Reply: third gen swap
