Sponsored by: DashLynx
Zaino question?
Old 12-18-2007, 12:13 PM
LS1SSZ28's Avatar
Default Zaino question?
Hey i just bought the total zaino kit, but dont have a buffer....to really enjoy zaino should i go ahead and get a porter cable?
Old 12-18-2007, 12:22 PM
BAD2000TA's Avatar
No, the porter cable is mainly for polishing out small swirl marks. The Zaino gets applied best by hand. Use good microfiber cloths. Should be good to go!
Bri
Old 12-18-2007, 01:45 PM
LS1SSZ28's Avatar
cool cool
then i gues i will ask for the SLP cold air kit and smooth bellows with a lid...instead of the buffer
Old 12-18-2007, 06:27 PM
wannafbody's Avatar
If you got ZPC or ZAIO a random orbit sander is beneficial. I really like the power of the Ridgid 2611 from Home Depot. Get some foam pads. Apply Z5P, Z2P, CS and Z8 by hand.
Old 12-19-2007, 06:47 AM
LS1SSZ28's Avatar
Well i got the ultimate carshow kit
Old 12-19-2007, 07:21 AM
ChrisV 02 - Z28's Avatar
You do not need a buffer for zaino, all by hand. If you need a buffer to get the zaino off then something is wrong, it wipes right off. just make sure you have a clean surface to start with. for the initial application, wash in liquid dawn to remove all old was/polish, clay the car, wash again and then apply polish. after that all you need to do is use ther car wash and detail spray between applicaitons.
Old 12-19-2007, 10:48 AM
DBanks's Avatar
You will see best results with ANY product when using a buffer. There is no way you can be as consistant as a machine. Impossible.
Is it a necessity, no. A luxury, yes. Your results will greatly improve with the use of a buffer.
BAD2000TA's Avatar
cool cool
smooth bellows is a waste of money. save it on something better. I'm on the fence about the cold air kit. I don't see that it does much below 60 mph. get stuff that works. lid, if you don't already have. boxed lower control arms will help at launch. drag radials for grip. etc.
Old 12-19-2007, 07:55 PM
LS1SSZ28's Avatar
what about application of Zaino?
would a PC improve that?
Old 12-19-2007, 10:42 PM
wannafbody's Avatar
hand application for the "sealants"
Old 12-19-2007, 10:56 PM
MosesMcgregor's Avatar
no.
Old 12-20-2007, 12:29 AM
LS1SSZ28's Avatar
i thought zaino was polishes?
Old 12-20-2007, 09:47 AM
BAD2000TA's Avatar
Not really. A polish cuts fine layers off the surface to reveal shiny new paint under. Zaino is a sealant, that protects that shine and reflects light really well.
Old 12-20-2007, 10:21 AM
JohnS's Avatar
I only use white 100% cotton towels and applicators with Zaino.
