Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
~~can't start my 96 lt1 need help please //////////
Old 12-19-2007, 11:39 PM
a90sickz's Avatar
Unhappy ~~can't start my 96 lt1 need help please //////////
It started fine yesturday drove it normal and the next day i tried to start it and it wouldn't start i heard the fuel pump turning off and on (each time i try to start) and smelled gas i know it can't be the fuel pump so i thought it could be something electric its raining and my car is always outside.it trys to start i hear it cranking like it wants to. I also tried a jump start and NOTHING!
please if anybody could help i'd appreiate it.
Old 12-20-2007, 10:00 AM
jmm98LS1's Avatar
Sounds like your opti may have taken a dump.
Old 12-20-2007, 03:42 PM
BsGreenZ's Avatar
try the ignition module on the head, mine went out twice with no warning..
Old 12-20-2007, 10:04 PM
a90sickz's Avatar
I'ma try the control module... i'm not sure if auto zone/kragens could check them if there good or not, but if its not that then it could be the opti.
Old 12-20-2007, 10:59 PM
Camaro396's Avatar
shouldnt this be in the LT1 section? not the small/big block section.......
Old 12-23-2007, 02:59 AM
a90sickz's Avatar
i'm new on this... dam i tried an used control module but nothing what if i tired taking one of the spark plug wires and put a philips in there while i start it (if it doesnt spark) would that tell me its my opti or not **** im tired of ridin my bike to work haha knowing my car is my daily driver
Old 12-23-2007, 03:00 AM
a90sickz's Avatar
https://ls1tech.com/forums/sbc-bbc-lt1-lt4-performance-93/ this is part of the lt1 section right?
Old 01-09-2008, 05:00 PM
Camaro396's Avatar
Originally Posted by a90sickz
https://ls1tech.com/forums/forumdisplay.php?f=93 this is part of the lt1 section right?
you clicked on small block & big block chevy specific. the one you were looking for is the link above it. LT1-LT4 specific.
Old 01-09-2008, 05:39 PM
TT632's Avatar
a90sickZ,
Check for spark at the plug. That will tell you if the Optispark or coil is bad. If both are good and your smelling a lot of gas it may be dumping gas in the motor, Bad diaphram on the fuel pressure regulator or, less likely a stuck injector. I have had 2 regulators go out on Camaros last year.
Quick Reply: ~~can't start my 96 lt1 need help please //////////
