long tube install
Old 12-21-2007, 09:49 AM
wildn347's Avatar
Default long tube install
just ordered my long tubes and i have access to a lift so im guessing that would make the install a hole lot eaiser? and if there is anyone out there with some helpful directions feel free to let me know
Old 12-21-2007, 11:01 AM
00silverGTP's Avatar
tranny jack is helpful, as the tranny is heavy! I had to grind a tab off my block to get them in. just be patient and double check everything and you will be fine.
Old 12-21-2007, 11:06 AM
wildn347's Avatar
so you removed your tranny?
Old 12-21-2007, 11:23 AM
bryan04h's Avatar
im curious too, why did you need a tranny jack?? whatever anyway, have a friend help man...holding the tubes in place for a min can get to be quite heavy...do it in a well lit area so you can see everything....i suggest using fod boxes(or something to hold nuts & bolts) it isn't that hard to accomplish, check the stickies..
Old 12-21-2007, 11:27 AM
sworaz's Avatar
You can get them on without lifting/dropping tranny. You won't need to raise your motor either. Make sure to disconnect the steering knuckle on the driver side and you'll have to take the starter off for some room on the passenger side. I'm pretty sure we did driver side from top and passenger from bottom. (jeesh that was a while ago)
Good luck.
Old 12-21-2007, 11:28 AM
8a8mfh's Avatar
I used a jack like the one pictured. Except mine was from sears, the jack and two stands cost $99 about 6 years ago.
When I put my headers in I supported the car on the jackstands while doing all the work, to put the headers in i put the jack under the front cross member and went up all the way, once they were in i put it back down on the stands to do the rest. Car in signature, drivers side went in with a hard push, pass side went in no problem. Only thing I removed was the old stuff, spark plugs and wires.
Old 12-21-2007, 11:35 AM
wildn347's Avatar
whats yalls estimated time?
Old 12-21-2007, 11:39 AM
bryan04h's Avatar
anywhere from 8hrs to a....year if your lazy lol depends
Old 12-21-2007, 12:31 PM
F-117HWK's Avatar
Check out the Sticky on Exhaust...The header section is down a little and EXTREMELY helpful. Good luck!
https://ls1tech.com/forums/generation-iii-external-engine/520845-mod-guide-induction-exhaust-please-read-before-posting.html
Old 12-21-2007, 01:27 PM
LS1>girlfriend's Avatar
did mine in 6 hours with an extra set of hands. i didnt have to remove the steering knuckle, didnt have to lift the engine, had to cut a tab off the block, but didnt have to grind the k-member at all. diff headers fit differently, so my advice is to remove the wires and spark plugs, then shimy the headers up as far as they'll go until you hit something or they slide in.
Old 12-21-2007, 01:37 PM
sevenstarsfall's Avatar
Did mine in 4hrs with a friend helping. Only problems we ran into was two manifold bolts stripped comming out, egr was a lil pain to get hooked back up and had to mess with the y for a while to get it to fit correctly. Other than that the headers slid right in with no disconnecting the steering shaft, lifting the motor, grinding anything, etc......goodluck on the install.
Old 12-24-2007, 04:35 PM
lol...opps. I was thinking about my clutch install. sorry, disregard the tranny jack.
it took me and a friends about 4 hrs with a lift to do the lts
Old 12-24-2007, 05:23 PM
snake hunter's Avatar
The only thing I had to do was cut a block tab on the driver's side. Go ahead and do that and you will not have to remove the steering knuckle. Takes about 30 seconds with a sawzall. If you have to grind the k-member you are doing something wrong. Did mine in about 8 hours, but I took my time. Also a 10mm ratchet wrench saved me a lot of time for the passenger rear bolt. (do that one from underneath. Also you probably won't be able to get a torque wrench on that one.) Torque to 18ftlbs starting with in the center. Good luck. You'll do fine. The lift will be a great asset. BTW, remove your plugs and wires. Should be evident, but just in case you weren't planning on it, you really have to do that too.
Old 12-24-2007, 07:55 PM
01CamaroZ28's Avatar
its pretty easy to do. installuniversity.com has a nice writeup
Old 12-24-2007, 08:15 PM
Adriana Lover's Avatar
Really easy to do!! Especially w/ a lift. Took me 4hours by myself in the driveway w/ 4 jack stands and a floor jack. Honestly the hardest damned part was the freaking gaskets lol. Took me about 10-15 mins a piece to get those bastards to stay while i held up the header and threaded a bolt.
Just remember to be patient and try different angles. I was able to get both in without having to remove or cut anything aside from the heat shields.
Didn't touch the motor mounts
didn't have to lift the motor
didn't even look at the steering rod
Didn't have to cut the block
Nothing just slipped em right in and bolted em up. Pacesetters btw.
Old 12-25-2007, 01:35 AM
THE PUNSSHR's Avatar
About 5 hrs taking a few breaks and with a extra set of hands. I replaced headers, spark plugs, wires, motor oil, and tranny fluid all at once. Just take your time with the header install. Having the right tools will be a big help.
Old 12-25-2007, 06:16 AM
wildn347's Avatar
i wouldnt think i need any specialty tools would i?
Old 12-25-2007, 06:47 AM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
I used the Tranny Jack to lift the motor from the K-member 1.5" while it was up on the lift. Made the install a hell of allot easier and quicker. That 1.5" makes a diff depending on the headers your using!
Old 12-25-2007, 07:23 AM
bryan04h's Avatar
hmm that does make sense, did you loosen up the engine mounts?
Old 12-25-2007, 02:22 PM
lol,.. Well yea,... You actually have to remove the bolts from the mounts or else the sucker won't even budge. Especially mine considering that they're polly!
