T56 Problems
T56 Problems
Ok I Have A 02 Ws6, The Problem Is That The Shifter Is Very Very Stiff. I Have Never Had This Problem Before, Even In Neutral Position I Can Barely Move It, Is My Shift Linkage The Problem?? Going Into Any Gear Is A Workout Entirely, the clutch seems to be working fine, it has normal pressure and is grabbing. The Car Is Just Sittin Right Now But Im Military And Need It To Drive Back Once My Leave Is Up. Want To Fix The Problem Myself But I Dont Want To Spend My Entire Vaction Working On My Trans. Any Input Is Helpful, Thanks Alot Guys
Scott
Scott
I went a few passes on it, It stuck it in forth gear I had to jam on it to get it out of gear. I drove it home with few problems but then it just completely tightened up.
