possible to keep F1C under 10# w a 4.5" pulley?
I will be installing a F1C on my stock bottom end C5 and was wondering if I could possibly keep the boost under 10# with a 4.5" pulley and a restrictor plate? I also have a G5X3 112 cam that I'm currently running which I hope will bleed off a little boost. I will be getting a forged motor eventually but wanted to hold off untill a year from now and then shoot for over 800rwhp. Thanks in advance!
8 sec potential, 12 sec slip
Maybe if you keep it under 5000 RPM... I don't know how big the crank pulleys are on the C5 kits, but with a 7.65/4.25 combo on my regular F1, I see 15psi with a 224/232 .581/.595 114+2 cam. Plus, the f-body intake hat is way more restrictive than the C5 intake is to the head unit. Only way I see you being able to stay at 10# with an F1C is to keep the RPM's down. Even at 10# tho, you will be walking a fine line. Better have an ultra conservative tune and some meth would help as well...
Elvir-which blower bracket are you going to run?
I'm was going to run the stage II ECS bracket but now I'm not so sure since the largest pulley I can run on the stage II bracket is a 4.5" pulley. I might just have to get their stage I bracket unless I can find a for sure way to keep boost under 10# with the stage II. Either way I'm sure I can't go wrong but I just had my mind set on the stage II bracket. Maybe Chris and Doug could set me up with a few restrictor plates to experiment with.
Elvir-with there new bracket the smallest pulley you can run is 4.25. I would just get there Stage 1-it works fine and I think they were selling them for like $600? I don't like the restrictor plates-if you restrict flow into the blower it can lead to belt slip.
If you need more midrange, crank that boost up
Arun-have you chosen which head unit you will be running with your setup?
