F1 Racing Chromoly Flywheel
Old 12-27-2007, 01:15 PM
3fourty6's Avatar
Default F1 Racing Chromoly Flywheel
Has anyone ever used one of these or heard of someone using one. I seen it on ebay. It seems like a really decent price but I'm concerned it could be a cheap piece of equipment. Thanks for any imput on this.
Old 12-27-2007, 02:08 PM
Black02SLPSS's Avatar
I would like to know as well. I was very tempted to buy one when i saw it floating around on ebay..
Old 12-27-2007, 06:18 PM
3fourty6's Avatar
Anybody?? Or is this against the rules to talk about??
Old 12-27-2007, 07:39 PM
98TADRIVER's Avatar
and more importantly is is SFI approved and what not?
Old 12-28-2007, 02:07 AM
3fourty6's Avatar
It says it is
Ultra heavy-duty and weighs only 15.45 lbs (Stock flywheel weighs 24 lbs)
Meets or exceeds SFI 1.1 specification
Made from 100% 4140 chromoly steel (2X stronger than Billet Steel)
F1 Racing Lightweight Chromoly flywheels incorporate special design features to enhance the airflow for improved clutch cooling
F1 Racing Lightweight Chromoly flywheels work with every clutch including Exedy, ACT, Fidanza, Clutchmasters, and other OEM clutch kits
CAD designed, CNC machined and computer balanced
Sure sounds tempting
Old 12-28-2007, 06:40 AM
slvrhwk's Avatar
I'd like to know as well.
Old 12-28-2007, 04:52 PM
3fourty6's Avatar
It sounds like a nice product. I guess I might have to be the test rat. I'm just not sure if I need to be going that light as my bottem end power sucks already.
Slvrhwk- I like that speed limit sign in your sig, nice touch
Old 12-30-2007, 06:10 PM
playboy245's Avatar
any one have any updates on those f1 flywheels, i'm getting very tempted.
Old 01-02-2008, 10:55 AM
Datsun350Z's Avatar
I bought one, when I get my car up and running which will be very soon, I will let you all know how it is.
Old 02-27-2008, 02:05 PM
slvrhwk's Avatar
Any updates?
Old 02-28-2008, 11:45 AM
ennovations's Avatar
Well if you are going for lightweight... a Fidanza flywheel weighs 12.5 lbs. and you can pick one of these up on ebay for around $250 new.
Old 02-28-2008, 12:52 PM
Internet Mechanic
BlackScreaminMachine's Avatar
It maybe "Stronger" then steel but its usueally more brittle. Id still be worried about it exploding off a 6k dump.
Old 03-14-2008, 01:05 PM
allforspeed's Avatar
any updates? the findanza aluminum ones warp bad sometimes, because of the two different types of metal heating and cooling at different rates, if this F1 works, could be really interesting, i put one on a honda crx and it seemed like a really good piece and made a big difference in reving
Old 03-14-2008, 02:52 PM
SPEC-01's Avatar
Chromoly sounds like a good material in theory...though as mentioned above it can be considerably more brittle than a Billet Steel or Billet Aluminum flywheel. The other thing to remember is that this material has a tendency to warp in high heat applications.
Someone referenced the tendency for Fidanza wheels which use a steel insert (similar to ours) to warp. We use inserts on a number of applications (all of our aluminum and even some of our steel) and even in the worst case scenerio with the most heat all you will have to do is replace a friction surface. That can't be said for a chromoly flywheel which, when heated, will warp the entire unit. Many times in an attempt to bring weight down these chromoly flywheels are cut very thin which can lead to a greater potential for warpage all together.
I know some of you will think I am trying to push our product by talking down another...but this is not the case at all. Though I have not personally inspected this specific product I am speaking from experience in regards to other similar units that we have inspected over the years. I just want you all to know what to expect when using a flywheel made of this material. To be honest, if it were a good as it seemed, we would be making these ourselves. Let me knkow if you all have any further questions. Thanks!!!
Old 03-14-2008, 02:58 PM
Nightrydass's Avatar
FWIW; i have SLP's Billet Steel Flywheel and noticed a nice increase and accleration and am VERY pleased w/ it.
Old 03-16-2009, 09:27 PM
malott442's Avatar
I'm hunting down the proper clutch combination....... but I have an F1 flywheel that I am planning on installing next week.....
I'll let everyone know.
Old 05-26-2009, 09:59 PM
taws6m6's Avatar
How did it go? My friend has one that came with dowel pins sticking out on the face and its keeping his tex pressure plate from bolting up to it
Old 05-27-2009, 07:03 AM
FST SS's Avatar
I have an SLP flywheel also. The guy at SLP said it weighs 8 lbs. lighter than stock. He said a stock one weighs 28 lbs so that makes this one weigh 20 lbs. I could tell a difference in acceleration too. He said the SLP clutch is a 2002 ZO6, I'm wondering if the flywheel is a 2002 ZO6 also.
Old 11-28-2012, 04:36 PM
lq4240sx's Avatar
I've got one of these flywheels and a SPEC 3+ clutch and am having issues with engagement. I know the trans and master and slave are good. I've measured and used the shim and it shifts super notchy. I'm at the point where I know its either the clutch or the flywheel and am about to dump them both for a new combo. Does anyone have any thoughts?
lq4
t56
spec 3+
f1 racing flywheel
Old 12-03-2012, 12:49 PM
SPEC-01's Avatar
Lets see the parts! Can you send some pictures to me for assessment and this will allow for a better idea of the cause. Thanks!
Quick Reply: F1 Racing Chromoly Flywheel
