Clutch bleeding issues.... trying a Tick Master. $0.02 welcome
1 Post
Here's the Cliff Notes version of my issue:
1. Installed a LS7 clutch in August 2011. Somehow got air in my McCloud Master Cylinder. Bled the crap out of it over the course of 8-weeks. Never got it perfect, but good enough for daily use.
2. April 2012. Melted the 6th gear bearings on my T56 driving triple digit speed in Germany. Got a replacement "Level III" RPM Trans through VA Speed. Had VA Speed install. Within 2 days was hanging up in gear.
3. Since April. Bled the Master at least 50x. Even bench bled it and used a MitiVac. After bleeding, worked like a dream..... for about 2 days. Then was hanging up in gear and getting a "soft" pedal. If I pump the pedal a few times...works OK. Hold the pedal down for several seconds.... crappy performance and hang-up, especially on the 2-3 shift.
In short, I think I'm getting air into the Master cylinder. No external leaks, but heard bad things about the McCloud unit doing so. My McCloud is now 7-years old with about 50K miles on it.
So, bought a Tick today from SpeedInc. Only concern is the LS7. Based on the "search function", the LS7 is self-adjusting. Hope that won't screw me by changing Master Cylinders. This is my real concern. I really hate to replace a LS7 clutch in great condition (5K miles) because of the self-adjuster.
In short.... think the Tick will solve my issue? Might be pure speculation.... but after pulling my tranny 4x in the past 18 months, I really, really, really don't feel like doing it again!
$0.02 welcome.
Thanks for reading.
$0.02 welcome.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
The tick is perfect for any clutch and actually made my buddies LS7 feel much more responsive... i personally have a Monster Clutch with mine and i wouldnt have it any other way.
1 Post
My main concern was that I read the LS7 clutch "self adjusts" and wreaks havoc on the settings of aftermarket Master Cylinders. All the info I've found thus far is when swapping a stock MC for an aftermarket one. Since I'm going from a McCloud to the Tick..... wasn't sure what to expect from my LS7. Hoping it works well.
As per prior posts....I've had the tranny out 4x in the past year sorting out my shifting issues. I really, Really, REALLY hate hoisting that biotch out of the car at home when it weighs 200lbs+. I'm hoping to avoid pulling the stupid trans a 5th time to replace an "almost-new" clutch for proper shifting!
while this won't fix your MC issue...go buy a $50 Harbor Freight tranny jack....worth every penny
1 Post
UPDATE - Installed the Tick MC today. It's a pretty stout unit. Almost a shame it's hidden under the brake booster.
I bench bled the MC before installing. Used the JMP method to bleed the system after install. Have the pedal set approx 1/2" lower than the brake pedal. It passed the "rev" test and engages the clutch around 1" off the floor at this setting.
So far so good. On a 6-mile stop/go test drive it was perfect. Pedal remained firm and the trans shifts very smooth. Taking a 250 mile trip tomorrow into LA to see how it really holds up
That'll be the "real test".
Appreciate the comments and help thus far.
So how did it do on the trip? I have a ls7 clutch with stock master cylinder and I've been wanting to put a tick m/c in it, since I think the stock one is going out on me.
1 Post
I'm going to set the clutch pedal even with the brake pedal this weekend. That should smooth the 2-3 shift at WOT.
Overall, quite happy with the current setup.
Car did great on the trip, aside from the fact I need to adjust the catch point a bit. I originally set the clutch pedal around 1/2" lower than the brake pedal. This is a bit too low. It's notchy at high RPM shifting from 2nd to 3rd. Aside from that it's very smooth and there's been no loss in hydraulic pressure.
Overall, quite happy with the current setup.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Very happy that our product fixed your issues!!! We 9/10 set the clutch pedal level with the brake pedal and leave it there. Even though every car will need a slightly different pedal height, it is a great starting point to begin with.
Not trying to hijack but since Tick is in here I was wondering if you guys could take a look at my issue:
https://ls1tech.com/forums/manual-tr...t-delayed.html
I'm pretty sure all I need is a tick MC and speed bleeder and it will be good. Thanks guys.
