225 heads or 205s
Old 12-27-2007, 07:33 PM
_916ls1z28_'s Avatar
Default 225 heads or 205s
i have a 98 ls1 camaro i used to have a lt1 with lt4 heads i just got my ls1 . i want to build my car. should i build the block or should i just add the head and cam on stock block i also want to go later on down the road with ether TT or sts . is the 90mm the bigest intake
are afr heads the best heads? let me know thanks ..............
Old 12-27-2007, 07:59 PM
RareBreed0295's Avatar
If you are going on stock cubes..i would go with the 205s.
Old 12-27-2007, 10:32 PM
Detoxx03's Avatar
stock cubes get the afr 205's. I plan on getting them sooner or later
Old 12-27-2007, 10:58 PM
SlowZ28/SS's Avatar
What they said. 225's will hurt you more on low end then help. Then again. For later down the road. If your going to TT it then you need forged internals and then the 225's would help quite a bit. It really all depends on how soon all of this is goin to take place. Just my opinion, but either way, good luck
Old 12-27-2007, 11:09 PM
Adriana Lover's Avatar
Listen to the fellas. I used to work there (AFR) and that's what they recommend themselves.
Old 12-27-2007, 11:33 PM
tavi_ws6's Avatar
205's for stock cubes for sure
Old 12-28-2007, 02:20 AM
bryan04h's Avatar
+1 205's you can put down a lot of power with some ported 205's and a nice cam....there is nothing wrong with that
Old 12-31-2007, 10:53 PM
thanks if i go internals ill go forged forsure maybe 408 or lsx block .
Old 12-31-2007, 11:07 PM
slowjoe99's Avatar
then get the 225s
Old 01-01-2008, 02:27 AM
bryan04h's Avatar
well if you are going with a 408 block then go with 225's
Old 01-02-2008, 10:44 AM
teke184's Avatar
a good performing h/c motor now....or a blower motor for later...
2 totally different engines...figure out which you want to do now...go from there.
what you build for a blower will hurt your N/A power. and vice versa.
Old 01-03-2008, 11:29 AM
black01_WS6's Avatar
the 225 will perform on the stock block. If you are planning on going with a new motor in 2 months or 3 years I would still go with the 225's.
Old 01-03-2008, 10:25 PM
BriancWS6's Avatar
For your current goals get the 205s, and make sure you mill them for extra compression
