Northwest Members WA, OR, ID, MT, WY, SD, ND
Coil Packs Relocated
Old 12-30-2007, 01:08 PM
WAHUSKER's Avatar
Default Coil Packs Relocated
I finally got this little project finished. This has been done before to other place, but this my version. And the real reason why I removed the AC unit.....
The 1st batch is the location, and the bracket build:
Attached Thumbnails Coil Packs Relocated-block-off-cover-sm.jpg   Coil Packs Relocated-coil-pack-bracket-sm.jpg   Coil Packs Relocated-coil-pack-bracket-sm-2.jpg   Coil Packs Relocated-coil-pack-mounted-sm.jpg   Coil Packs Relocated-coil-pack-mounted-sm-2.jpg
Old 12-30-2007, 01:11 PM
WAHUSKER's Avatar
And here it is installed. Now I need to rework the wire harness a little to make the connections & hang it off the firewall (along with the plug wires to the driver's side)
Attached Thumbnails Coil Packs Relocated-coil-pack-installed-sm.jpg   Coil Packs Relocated-coil-pack-installed-sm-2.jpg   Coil Packs Relocated-coil-pack-installed-sm-3.jpg   Coil Packs Relocated-coil-pack-installed-sm-4.jpg
Old 12-30-2007, 01:18 PM
turbo50's Avatar
Looks sweet Mark.
Old 12-30-2007, 02:30 PM
99LSS1's Avatar
Looks like that is going to work out pretty well Mark. Gonna need some long *** wires to get to the plugs on the other side. Should look really clean when your done.
Old 12-30-2007, 03:19 PM
HitmanLSX's Avatar
Looks awesome... When did you get the MSD coils? I don't remember seein those last time.
Old 12-30-2007, 04:40 PM
99blancoSS's Avatar
Those tuck in there nicely. Good job.
Old 12-30-2007, 04:46 PM
WAHUSKER's Avatar
You'd have been hard pressed to see the coils on the old car. One pack was under the main fuse box & the other was mounted on the frame rail where the AC compressor use to be. But I've had the MSds for a year.....
Old 12-30-2007, 07:41 PM
crazylane's Avatar
Are they worth the money you have to pay for them?
Cause I was thinking about getting them. But could not justify paying over 500.00 for just the coils. when stockers work fine.
Old 12-30-2007, 11:25 PM
howierd42's Avatar
That does look good tucked in there, Mark.
Old 12-30-2007, 11:31 PM
TwoFast4Lv's Avatar
Looks real good man!
Old 12-31-2007, 12:11 AM
Ackattack1's Avatar
what spark plug wires are you going to run (or which parts of what kit), cause I'll be relocating the coil packs in my project truck so I can run these
Old 12-31-2007, 08:57 AM
WAHUSKER's Avatar
Jay Fisher Pontiac makes & sells the coil relocation kits complete with 10.4 Taylor wires....
Old 12-31-2007, 10:51 PM
sardog46's Avatar
That looks sweet mark. can't wait to see the finished project.
Old 01-01-2008, 06:59 AM
99blancoSS's Avatar
So do I
Quick Reply: Coil Packs Relocated
