going rate for complete 9" ??
Old 12-31-2007, 02:24 AM
rewguy's Avatar
Default going rate for complete 9" ??
how much for a complete spooled 9" for 99 camaro nowadays? thanks for any info......
Old 12-31-2007, 02:41 AM
SuperSlow02's Avatar
too many options..but between 2k-2.5k
Old 12-31-2007, 02:54 AM
rewguy's Avatar
is that with brakes or without?
rewguy's Avatar
and what brakes?
Old 12-31-2007, 04:10 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com....html?item=148
Here is the Moser 9 inch, with additional options. It does not include brakes, although I can supply it with Wilwood brakes. Bob
Old 12-31-2007, 09:32 AM
Jays00ss's Avatar
I paid $2550 complete includeing shipping for my 9". which has:
Moser 9" houseing (with drain plug) and 35 spline axles with reluctor rings installed, Strange Pro Nodular third member with Motive Performance 4.30 gears and a detroit locker.
Place I bought mine from had outstanding customer service and Let me build my rearend the way I wanted with upgraded parts. It was on my doorstep 5 business days after I ordered it and the gears were set up properly and are nice and quiet.
Brakes are extra no matter where you buy your rear end.
Old 12-31-2007, 10:16 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
i have the Moser standard 9 inch with Strange iron case, spool, 35 spline axles for 2149.00 shipped.
my new fabricated housings(includes drain plug, 4 hole relocators, and antisway brackets as standard features) with a torque arm and tunnel or trans mount crossmember, 31-35 spline axles, and a complete Strange center section with spool start at 2400.00
i assemble all center sections and will custom build a whole package for you.
the stock 93-02 rear brakes can be reused on all of these rearends, or you can upgrade to Strange or Wilwood race style brakes.
Old 01-02-2008, 11:04 PM
Jawsgear's Avatar
Check out our website for pricing on 9" Ford Differentials....
use ls1tech in comment section for free shipping.
Jeff
Old 01-03-2008, 09:29 AM
LS1TECH Sponsor
Steve Burger's Avatar
What are your goals? This will impact your choice.
Old 01-05-2008, 04:24 AM
EPP
EPP's Avatar
Moser rearends are shipped out two days after the order is received! Bob
