Head light qustion?
Old 01-01-2008, 10:41 PM
Italiankid77's Avatar
Default Head light qustion?
I have a qustion my passenger head light wont come up,and it also makes a like a grinding noise do I need a new head light motor??
Old 01-01-2008, 10:46 PM
Mtown's Avatar
Yes you do. They are kinda pricey for something so small.
Old 01-01-2008, 11:02 PM
Duffster's Avatar
I don't have a bird or T/A, but don't they have issues w/gears (plastic) stripping out? Sounds cheaper than a motor. . .
Old 01-01-2008, 11:18 PM
Gordon0652's Avatar
Someone will chime in and tell where you can buy some metal gears to replace the factory ones. Damn i wish i knew the site.
Goodluck
Old 01-01-2008, 11:58 PM
TheGr8Schlotzky's Avatar
Sounds like the gears.
here is one place to get some nicer gears.
http://my.execpc.com/C4/4A/rodney1/firebird/
Old 01-02-2008, 12:38 AM
jRaskell's Avatar
I had a similar problem a few months ago with my driver side headlight motor. It was opening, but grinding when it closed. Bought the kit from Rodney in the link above. When I pulled out the original plastic gear, it was stripped in one section (that prevented it from locking the headlight completely closed). The motor doesn't use any sort of physical limit switches for open and closed position. It monitors current flow to the motor. When the motor loads up from no longer moving, the current spikes and the motor is shut off. The grinding sound is the motor grinding away at the stripped portion of the gear until some built in time limit passes (current never spikes because the motor never gets loaded).
Replacing the gear itself is pretty easy. Instructions are very good. Just don't do like me, and try to take the motor assemply out without taking out the headlight assembly. It's much quicker to just remove the headlight assembly, then the motor assembly.
I bought two kits myself, one for the passenger side as well, but I haven't actually replaced the passenger side. Just want it in the cabinet for when the passenger side does fail.
Old 01-02-2008, 02:58 PM
Copy & Paste Moderator
VIP1's Avatar
LS1Tech 20 Year Member
Sticky:
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
Old 01-02-2008, 04:36 PM
Undertow74's Avatar
yea i would say the gears before the motor.....esp if you can hear it grinding, that means the motor is atleast getting power and working. If you search for F-body replacement headlight gears im sure you will find some good metal aftermarket ones...
Old 01-02-2008, 05:17 PM
Thanks guys.
