Warm starts car wont idle??
Old 06-30-2003, 09:48 PM
DEEZ98Z's Avatar
Default Warm starts car wont idle??
Like said above, car doesnt want to idle on warm restart. Cold starts I have no problems and while driving I RARLY have any problems. What needs to be Edited?
Any help here would be great
Old 07-01-2003, 04:31 AM
Bink's Avatar
Default Re: Warm starts car wont idle??
Here you go...read this thread - warn/hot starts good luck.
joel(Bink)
Old 07-02-2003, 04:54 PM
DEEZ98Z's Avatar
Thanks... TTT
Old 07-02-2003, 06:37 PM
98TAauto's Avatar
raise idle
drill TB hole a tad more
turn TB set screw
add base spark in park and drive(just a few degrees)
some tweak the VE table also
Old 07-07-2003, 08:35 PM
DEEZ98Z's Avatar
Well I didnt know that the VE tables had already been trimmed.... So we just smoothed everything out and the restart are better. Now I think that I need to change my plugs, that should also help alot. Thanks for the info
Old 07-07-2003, 09:02 PM
MONZA679's Avatar
GO UNDER FUEL TABLE AND THEN UNDER MASS VOLUMETRIC EFFECIENCY, MULITIPLY 400-1200 TABLES ALL THE WAY TO THE BOTTOM BY 60%. I DID THIS AND COPIED THE HYPER TECH PROGRAM AND MY CAR RUNS PERFECT WITH STAGE 2 HEADS AND 561 LIFT CAM.
Old 07-08-2003, 12:55 AM
Ed Blown Vert's Avatar
I hear everyone saying to do this. But what does it do?
Old 07-08-2003, 09:51 PM
MONZA679's Avatar
leans out the fuel at idle on hot restart when car is in open loop.
Old 07-08-2003, 10:38 PM
Same thing on cold restart, open-loop?
Old 07-09-2003, 11:13 AM
Cal
Cal's Avatar
Cold starts aren't a problem because a cold engine can use the extra fuel
Old 07-09-2003, 11:34 AM
True. But my engine is very rich when cold, after I modify my IFR to lower LTFT's.
